Hi, JJG10101
I guess "it" does get mad
Ever wonder how RoboHelp automagically updates the path to
files when you drag and drop a topic from one folder to another *in
the Project Manager*? Well, all this info and a lot of other data
about the RH project is kept in the CPD file (which is an Access
database).
So, the rule is: Whenever you want to
Delete, Move or Rename a file in your project, you must
always do it within the RoboHelp interface so that the database is
kept updated. If these actions are done outside of RH in the
Windows Explorer it has no way of knowing what's going on behind
its back.
Fiddling with files in the Windows Explorer is easily the
most common cause of broken links.
As to your comment about files in other projects. Actually
there is no "linkage" between files in one project and another
(unless you've inserted a FrameMaker file by reference). So moving
files from one project to another would not be a good idea.
Naturally there exceptions to everything. For example, you
could copy a CSS file from one project to another as a way of
"importing" it into your project. By copying it to your project, it
will show up as an available style sheet in topic properties so you
can assign it.
Another exception might be if you wanted to share a Glossary
with a colleague. For example, you could send them the
"yourproject.glo" file and they could paste it to their project
folder. However, they would need to first delete their project's
default .glo file and rename the one you sent them to the name of
their project.
So, while there are exceptions, it's best not to mess at the
Windows Explorer level.
Thanx,
john
John Daigle
Adobe Certified RoboHelp and Captivate Instructor
Newport, Oregon
