I need assistance. The below script was written in HTML view to allow a topic to be emailed that provides a link directly to the topic vs to the home page.
It was working for about a year and now it does not work anymore. When the link is created and sent via email, the recipient of the email clicks on the link and it bring them to the home page.
Can someone review the script and advise what I need to do in order to correct it?
Thank you!
Hi there
I think we may need more information here.
For example:
Does it happen with any and all browsers or one specific browser?
What version of the browser?
What does the link destination look like when it has been hovered? For example, http://www.somesite.com/somepage.htm or whatever.
What is the output type? WebHelp, FlashHelp, Responsive, Multiscreen, etc?
Cheers... Rick
The default browser used is IE 8
Output is WebHelp
Here is an example of what it looks like when the email link is selected in HTML and added to an email window:
Data Clean-up FAQ: file://ustrysvpsqlcl9/appshare/DNN_Instances/DNN_Apollo/Portals/0/IDRPHelpFile/SSL/WebHelp/start.htm...
When the link is click it goes to the main home page instead of the topic. As mentioned before it used to work correctly and now it doesn't and there have been other people touching the application so not sure why has changed to cause this issue.
Thank you for attempting to help.
Joanna
Hmmm, okay. If I were in your shoes and trying to fix this, my first step would involve simply opening the FAQs_Data_Clean-up_FAQ.htm topic all its own in the output folder. And from there, depending on your SSL recipe settings, hopefully you will see a "Show" link in the upper corner. If so, click the link and note what is revealed in the address bar of the browser. Copy that URL and compare it to the one that doesn't work. Does it look any different? Paste it into a new browser. Does it work to open the topic?
Cheers... Rick
Is the link located in the topic or in the skin? For the skin, you may want to try my toolbarscripts: http://www.wvanweelden.eu/product/webhelp-pro-toolbar-scripts
Is the behaviour different when you place the output on file (as you're doing now) and when you add it to a webserver?
William,
I do have a toolbarscript attached to the skin and when I look at the Master Pages (HTML) it shows the script written in there as well. Should it be removed from the Master Pages, is that what could be causing the issue?
Joanna
Here is the code within the master pages:
function 'My customer title ' +GetTopicPane() {//Get the topic pane
var topicPane;
if (top.frames[0].name == "ContentFrame")
topicPane = top.frames[0].frames[1].frames[1];
else
topicPane = top.frames[1].frames[1];
topicPane.focus();
return topicPane;
function emailCurrentPage(){
window.location.href="mailto:?subject="+document.title+"&body="+escape(window.location.href);
I tested the WebHelp Toolbar Scripts and it works fine for me. The JS you posted is garbled and won't work since you simply get the window.location.href. Instead you need the CSH URL: The URL of the main page with additionally the URL of the topic relative to the project root. If you look in the code of the toolbar scripts, you can see how that works.
