4
bug report: Illustrator CC 2015 export artboards to svg
Jun 16, 2015 Jun 16, 2015
In new illustrator CC 2015 when I need to save every artboard as svg files (File--->save as..---> svg--> use artboard...) - the files is null (no artwork in the saved files). When I save and did not choose "use artboard" I can see artwork in saved svg.
When I open the same file in Illustrator CC 2014 - I can save artboard as svg without any problem.
59.9K
Adobe Employee , Jul 07, 2015 Jul 07, 2015
We have released a patch 19.0.1 that fixes the issue being discussed on this thread. Please apply the patch from your creative cloud application. The creative cloud application checks for update once a day hence you may not see the update right away.  If you want to force the check for an update early please logout and log back into the Creative Cloud application.
Link to the release notes of 19.0.1: https://helpx.adobe.com/illustrator/kb/illustrator-cc-2015-crash-bug-fixes-19-0-1.html
If you
Adobe
replies 106 Replies 106
Have the very same problem, only the head and view box are generated
I was going to suggest using Multiexporter script available on Github, but it seems that's been broken too
Export Illustrator Layers to SVG files | Thomas Byrne
I'm so glad that I kept my previous versions of CC apps when I upgraded. That's a workflow I can't do without.
Same problem here.. fix this asap!
Me, too! I used this functionality quite a bit. Adobe, please fix!
same problem as you all have described Ai 2015 is very buggy...i opened the file in Ai 2014 and the files saved with no issue. Adobe please FIX ASAP THX
Jun 17, 2015 Jun 17, 2015
Nthing the issue. Nearly-empty SVG output when using artboards.
Booo
Please fix this problem quickly
Have the same trouble (((
Reeka, others,
There seem to be some unsolved issues with CC 2015, not least concerning SVGs. You may wish to roll back to CC 2014, if uninstalled you may reinstall CC 2014 from the previous versions tab in the CC management app.
Using the CC desktop management app, go to the gear icon at the upper right. Find the Illustrator install and there should be an "In Previous Versions" option.
You may uninstall 2015 for now if you wish.
Well, why?
You can install them side by side.
Well, why not, Monika, for anyone wishing to await the solution of issues?
And it was not an advice, merely the statement of an option.
I've already reinstalled CC 2014.
Same issue here, I guess CC 2014 will work for the time being.
GRRRR.....   Get it together Adobe.
Same problem here.  I use this function to save out my svg icon fonts.
I reinstalled AI 2015; no fix.  I cant even go back to AI 2014.
If you have Creative Cloud is should be straightforward to re-download Illustrator 2014. Go to the Creative Cloud menu and scroll down the "Apps" until you see "Previous Versions".
AI 2015 seems to have disabled AI 2014 and it doesn't show up in that list.
As a semi-workaround, you can export each art board individually though.
Jun 18, 2015 Jun 18, 2015
I'm afraid that's the Creative Cloud app filtering applications in an attempt to be concise and "user-friendly". Here's a screenshot of mine and where you need to click to see all older versions. Click the blue "Previous Version" in "Find additional apps" and it will show you a list of filters. Click "All Apps". Illustrator should then show up. Click the "Install" button and it should show previous version numbers. You want version 18.0. You will now be able to reinstall Illustrator CC 2014.
Engaged ,
That worked!
Adobe Community Expert
Thanks for the help Drawingbuddy.  I am guessing there are multiple versions of Creative Cloud apps out there too... Here's my app with no dropdown options.
Does this mean there is no AI listed in your version of CC management app? Did you try clicking on the install button for AI? You will need to do this to get the list of options.
Jun 19, 2015 Jun 19, 2015
I assure you it's there. If you look on the right on your screenshot it says "All Apps". Click the dropdown menu there and scroll down to the bottom that says "View Previous Versions".
You will then see the full list with various versions available once you click "Install".
This shows the UI is very poorly designed.
thank you for posting this, helped me find it.
Jul 01, 2015 Jul 01, 2015
Thanks so much for providing the screen shot. That UI is really confusing.
Enthusiast ,
The forum isn't for bug reporting.
Use this form to file an official report:
https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
