quote:
Originally posted by: newportri
Thanks so much- I decided that rather than having a field hold comma-delimited data, I would go this route- i.e. create 9 more fields in each record to hold up to 10 codes- I was a little unclear on your first solution- and I'm under the gun.
Yes- each customer has exactly one row in main table and yes, form field code_01 corresponds to data in field vendor_cccode_01- so I think I can get this to work.
Thanks again.
Thanks again for your reply.
I understand that I would need to create a "junction" table that has its own key field, the vendor's ID and code ID foreign keys, but now this table needs to contain all the matching vendor/code associations i.e several thousand records?
Thanks - hope you had a great Holiday.
