Hello,
I tried to add this as a bug to the Coldfusion Bug tracker (https://bugbase.adobe.com/) but ironically, I get a default Coldfusion error page when I log in.
I believe there is a serious bug with the for-in construct when used in a particular fashion. In particular, if the "in" expression is a function call, it appears that the function is invoked multiple times (to be precise, it always appears to be 5 times).
Clearly there are many situations where this could have serious consequences, not least if the function does any serious work.
Key points:
Workaround:
Severity:
This a serious issue as,
Speculation:
I speculate that the code is pre-processed into a construct that does (in clause).size() (in clause).iterator(), etc
Test Case:
See below for some code which tests this:
component displayname="ForInTest" {
ForInTest function init() {
variables.count = 0;
return this;
void function test1() {
for( var item in getArray() ) {
// do something interesting
if( variables.count==1 ) {
writeoutput( "getArray() was called once." );
else {
writeoutput( "getArray() was called multiple times! (" & variables.count & ")" );
void function test2() {
var items = getArray();
for( var item in items ) {
else {
private array function getArray() {
variables.count++;
var data = [1,2,3];
return data;
var test = new ForInTest();
test.test1();
test.test2();
Output:
getArray() was called multiple times! (5)
Have something to add?
