Lightroom CC - cant get Canon print studio pro to load/work
Jun 16, 2015 Jun 16, 2015
I recently downloaded Lightroom CC +  Photoshop CC, but after loading Canon Print Studio Pro it does not show on add-on list or Canon utility folder.
15.2K
New Here , Oct 17, 2015 Oct 17, 2015
There was an error in the address the link is here
Print Studio Pro Ver. 1.4.1 (Windows 10/10 x64/8.1/8.1 x64/8/8 x64/7/7 x64/Vista/Vista64/XP)
With regard to Lightroom the plugin should actually be installed in
Program Files/Adobe/Adobe Lightroom/Modules not as stated
It works for Lightroom 6.2
On my Windows 7 computer, using Lightroom CC 2015, the Print Studio Pro plug-in shows up in the File->Plug-in Extras option. I know that the Mac doesn't have a File menu option. But it would be the leftmost menu option on the Lightroom menu bar.
Hi Jim,
thanks for your email - it doesn't show on the plug in extra options - its just blank. It shows on my program list on windows control panel - but when I tried to delete it - it doesn't?
any ideas?
Cheers
Chris Hendrie
I don't know what to tell you. I simply installed the plug-in in Lightroom 5. When I switched to Lightroom CC it just it just carried over. I don't use it very often, however. I usually prefer just to print directly from Lightroom.
ok - will just give that a try
Jun 17, 2015 Jun 17, 2015
‌I updated also photoshop cc 2015 and now I cant't use Print studio pro with Lightroom or Photoshop.  I have tried many times with different ways but have not succeeded.  I have a busy printing project going on and should travel next week.  I really hope that somebody would give us an answer.
I tried Adobe online support last night - a real joke - to put it polite.  I explained to the idiot countless times the situation - and all he said was reinstall it!!!
Hopefully there will be an update soon...............
Jun 18, 2015 Jun 18, 2015
C'est très simple. Tu copies les plug-ins qui sont dans Applications/Adobe Photoshop CC 2014/Plug-ins et tu les colles dans Applications/Adobe Photoshop CC 2015/Plug-ins. Ça fonctionne très bien !
Doesn't work
Jun 20, 2015 Jun 20, 2015
I installed LR5 from the previous version section in Creative Cloud and then reinstalled Print Studio and it has become available in LR CC 2015 . Works fine so far , not sure if it will work if LR5 is removed though .  It will do until an update from Canon is released . Hope this helps .
Aug 04, 2015 Aug 04, 2015
I have just been through the same process.
A call to Canon Europe cleared it up for me, they were very apologetic, but they have not yet released an LR6 compatible version of Print Studio Pro.
They could not tell me when to expect it, but will email me when it becomes available. Great support team.
PS
  • The Canon site's documentation was clear that LR5 was the latest version supported, I misread it.
  • An error message when I attempted installation was also clear, that a compatible version of LR was not found.
  • I tried to fix the unfixable by bypassing the procedure recommended.
All my fault really. However I learnt a lot more about LR6 superb printing capabilities as a result.
Contributor ,
Sep 26, 2015 Sep 26, 2015
I just downloaded version 1.4.1 of Print Studio Pro (had to search around the canon site quite a bit to find it). - here is a link http://www.canon.co.uk/support/consumer_products/products/printers/inkjet/pixma_pro_series/pixma_pro...
That eventualy started in Lightroom CC 2015 after I had manually added it to the plug-ins - it resides at C:\Program Files\Canon\Print Studio Pro\CNPSPPILR.lrdevplugin.  However even having installed the plug in using add in the Plug-in manager it still does not work, it fails with the message that it can't find CNPSPOPN.exe in the CNPSPPILR.lrdevplugin directory.  In fact this .exe is sat at the next level up in the Print Studio Pro directory - the easy solution is to copy this .exe to the .lrdevplugin directory.  I copied rather than moved the file and after doing that Print Studio Pro worked perfectly in Lightroom CC 2015.
However I have failed trying to get it to work with Photoshop CC 2015.
Contributor ,
Sep 28, 2015 Sep 28, 2015
The instructions for installing Print Studio Pro in Photoshop CC 2015 under Windows 10 are in the following link.
https://www.usa.canon.com/nw3s/CanonUSA/DownloadContents/English/0200218402EN.htmhttp://
It worked for me.
Dave, The link you provided above does not work. I get the 404 not found message.
May 07, 2016 May 07, 2016
This link worked.  The link is for V2.02 and I did not have to copy directories.
Jun 10, 2016 Jun 10, 2016
Thank you for this helpful tip! I was about to give up and because of this tip, it works fine now!!
Aug 24, 2016 Aug 24, 2016
Legend, this worked for me straight away. I had exactly same problem. whole reason I bought pro100s was to have full control over my fine art prints. anyone else having same issue with print studio plug in not working on lightroom cc then just follow these instructions step by step and will then work
This was the best answer!! Thank you!! I use Windows 7 and CC and  works now!!
Participant ,
Dec 14, 2016 Dec 14, 2016
I am also having trouble finding Studio Pro in my Photoshop CC 1915.  I'm using Mac 10.11.6  OS X El Capitan.  I have a Cannon Pro 1 printer purchased in November 2013.  I have downloaded the plug-in from the web and have also tried installing the plug-in from the disk I received when I purchased the printer.  I've also tried moving the plug-in to the 'plug-ins' folder in Photoshop CC 2015.  Still can't find it - not even in File/Automate as suggested in this thread.
Mar 15, 2017 Mar 15, 2017
i have the same problem did you find out how to do it ??
I just installed the plug-in using the installer downloaded from Canon. The plug-in shown in both Lightroom and Photoshop. But I don't see what the big deal is about the plug-in. I have a lot more flexibility printing directly from Lightroom or Photoshop.
