Hi all,
I can't install Flash player using flashplayer18_hd_install.exe. It always stops saying that it has failed to install and nothong else. I tried to do it while stopping anti virus but no hope.
I use Fire Fox but the browser was stopped when I tride to install.
Any clue?
Thanks in advance
Michel
Hi msalais,
I'll need to get some log files from you to troubleshoot further. Please do the following:
Thank you.
Maria
Thank you. We're reviewing the log files.
Hi msalais,
I'm still working with the online installer folks to resolve this issue. In the mean time, please try using the offline installer posted at the bottom of the Installation problems | Flash Player | Windows page in the 'Still having problems' section.
Maria
Hi Maria,
I have tried the link for the offline installer and it works fine.
waiting your comments on the other installer problem.
Michel
Hi msalais,
The online installer team is still looking into the issue. Thank you for confirming that the offline installer worked for you.
When you downloaded the online installer, did you save it to your local machine or external drive (i.e. usb drive)?
Maria
Hi
I save the file on local disk. However, I must say that this is a VMWare machine using Vmware Workstation 11. The file system on which I save the file is a shared vmware volume.The vmware host is an Open Suse Linux.
Michel
Hi msalais,
The additional information you provided enabled the online installer team to reproduce the bug. It is in their queue to be fixed, however, at this time there is no estimate when that will be. In the mean time, please save the file locally within the VM guest instead of to a shared location.
Thanks again.
Maria
OK!
Well I know now how to avoid it.
Thank you.
Michel
De : m_vargas
Envoyé : vendredi 19 juin 2015 20:23
À : Michel SALAIS
Objet : Flash Player 18 upgrade problem on Windows 8.1 Pro
created by m_vargas <https://forums.adobe.com/people/m_vargas> in Installing Flash Player - View the full discussion <https://forums.adobe.com/message/7667116#7667116>
