Hi everyone,
I just installed the CC 2015 today (terrible regrets), and i working with dynamic link premiere to after.
So i keep two softwares open and everytime i start a render in Premiere, appear this message in After Effects (After Effects error: FLT_GeneralEffectCallPlus can not be called reentrantly (25 ::222)) so this annoying message are stucking my render everytime, and i have to close one of the programs to working with a normal workflow.
Please, someone know how to solve this? (sorry for bad english)
The After Effects CC 2015 (13.5.1) bug-fix update is now available, which addresses this bug:
Same Here
25 :: 222 | Mylenium's Error Code Database
Probably something similar, but one would need to know which effects and tools exactly are used.
Mylenium
I have the same problem here.
I'm having the same problem, and I have a deadline coming up. Adobe never fails to piss off its customers. Only if they didn't have monopoly and there was some competition...
Is this happening when using the Warp Stabilizer effect?
Yes, seems that way.
Yes for me !
YES. SO far the only thing I've tried is warp stabilizer.
If you have a deadline, use CC 2014 to get it done and THEN play with the new version.
I would say, IF a company is incapable of running the simplest tests to find bugs before releasing a new version, they SHOULD announce that their new version is unstable and in beta mode.
The problem mentioned in this thread is not my only problem. I'm getting a couple of other annoying errors as well.
And to Todd_Kopriva, not in my case. I don't have any Warp Stabilizer in my project.
Any ideas on download links for the previous versions?
Uninstall the CC 2015 versions, run the cleaner tool and then check the "Previous versions" section of your CC app.
Use the Adobe Creative Cloud Cleaner Tool to solve installation problems
Mylenium
I tried uninstalling and running the cleaner like you said. The problem I'm having now is that it will not let me use any previous versions. It is forcing me to download the 2015 version. I am getting so frustrated with this!!!!!
You don't have to download only the latest version. You can have CC 2014, CC, or CS6 too. How to Find and Install Previous Version of Adobe Apps in CC 2015 | Adobe Customer Care Team
Szalam ... i'd rather not say anything to your comment, I wasn't aware CC15 was just for playing with.
Todd_Kopriva‌ Yes, it looks like it's warp stabiliser related. I started a new project in PP15, add a media, replace with AE comp (AE15), put some effects, all ok, dynamic link ok
then I add Warp Stabiliser VFX on it, still all ok.
Then I "Analyze" the content, when it's stabilised, I get the error message
Thanks for your help
I'm having the same issue. I uninstalled everything and used the cleaner and it didn't work. Another issue I'm having is my AE clips on the Premiere timeline won't transfer over to Speed Grade when I try to use that. I get the Red Screen of Failure for each of those clips.
Also, I just noticed my graphics card, Quadro 4000, is not on the list of recommended cards for this release. Is that a thing? Or can we pretend that didn't happen?
Hey, I do have the same bug, so I saved the project closed AE before getting back to Premiere. So it's ok for the moment.
I hope Adobe is getting the bug fixed very soon...
Same issue here. Like binford said, if you don't open both applications at once you can at least get some work done...but that problem has to be fixed as soon as possible!
You can also use Warp Stabilizer effect in Premiere..if it's any help..
We also have this problem with after effect cc 2015. The solution proposed by binford (having just on application launched at a time) is a trick but seems to work so far. Do adobe teams work on a bugfix ?
And now i got it to! Got some mask tracking and some text tracking in the comp that generate the error. Have to "force" close AE and start it over. The error show when i first switch from PP into AE then back to PP and again back to AE, then the error is there. And it's a dynamic link comp in premier from AE.
AE project using Warp Stabiliser VFX on 4K footage and Ray-traced 3D comps causes this error - but inconsistently. No dynamic links.
Each time, the dialog box prevents further access to the program, forcing a termination from task manager.
In general, AE CC2015 responsiveness is noticeably lower than CC2014, especially whilst generating previews (clicking away, then clicking back causes long app waits). Quadro K5000 CUDA performance seems higher though.
It is most definitely a beta release!
Please adobe get this fixed as soon as possible. We would much appreciate it if you did. Thank you.
I'm also seeing this problem. Dynamic link comps not updating in Premiere. when I create a Dynamic link comp in the Premiere timeline it throws me over to AE but gives me a 'generic error' in premiere and the Dynamic linked comp fails.
Very frustrating. Even importing an AE comp the traditional way through Premiere doesn't work correctly. Even after reserving everything the comps don't show up in in the import menu in Premiere.
The only solution seems to be to relaunch. Far from Ideal.
Fix please!
