How do I use cfloop to insert numbers that are not rounded?
Jun 24, 2015 Jun 24, 2015
I ran the following code and it displayed my numbers correctly, ie: 1.75, 2.50:
<cfloop from="1" to="#getnumba#" index="idx">
    <cfset getunit = form["unit" & idx]>
<cfoutput>#NumberFormat(getunit, "99.99")#</cfoutput><br />
</cfloop>
<cfabort>
But when I tried the following code, it rounded the numbers again:
               <cfset getqty = form["qty" & idx]>
    <cfset getitem = form["item" & idx]>
<cfif (getqty is "") and (getitem is "") and (getunit is "")>
               <cfset getqty = 0>
    <cfset getitem = 0>
    <cfset getunit = 0>
</cfif>
<cfquery name="insertItems" datasource="#application.dsn#">
INSERT into items
(orderID,
               qty,
               item,
               unit
VALUES(
<cfqueryparam value="#getoid#" CFSQLType="CF_SQL_INTEGER" >,
<cfqueryparam value="#getqty#" CFSQLType="CF_SQL_INTEGER" >,
<cfqueryparam value="#getitem#" CFSQLType="CF_SQL_VARCHAR" >,
<cfqueryparam value="#NumberFormat(getunit, "99.99")#" CFSQLType="CF_SQL_INTEGER" >
</cfquery>
</cfloop>
263
Advocate ,
Just a guess but in your cfqueryparam you are specifying CFSQLType="CF_SQL_INTEGER".
As mentioned by Steve, above, CF_SQL_INTEGER is causing the issue. Try CFSQLType="CF_SQL_DOUBLE" or CFSQLType="CF_SQL_FLOAT", or CF_SQL_NUMERIC and CF_SQL_DECIMAL. by adding the additional attribute, scale=1,2,3.... [scale => Number of decimal places you want passed in parameter. Applies to CF_SQL_NUMERIC and CF_SQL_DECIMAL].
For example:
<cfqueryparam value="#NumberFormat(getunit, "99.99")#" CFSQLType="CF_SQL_DECIMAL" scale="2" >
Jun 29, 2015 Jun 29, 2015
Thank you gentlemen, the problem has been solved. I don't know why I wasn't notified of your responses.
Documentation
