Open Old FrameMaker Documents with ExtendScript
Jun 24, 2015 Jun 24, 2015
I am trying to open a FrameMaker 5.5 document using scripting and convert it to XML.
I can open the files in the interactive version, but when I try to open them in FrameMaker 2015 using ExtendScript it just won't open.  No return parameter errors.  Just says not valid document.
Is there a parameter I can set in the open parameters to allow this?
Anyone have an example of how to do this?
Paul V
Scripting
1.2K
Community Expert , Jun 24, 2015 Jun 24, 2015
function openDocOrBook (filename, structuredApplication, visible) {
    var i = 0, docOrBook = 0;
    // Get default property list for opening documents.
    var openProps = GetOpenDefaultParams ();
    // Get a property list to return any error messages.
    var retParm = new PropVals ();
    // Set specific open property values to open the document.
    i=GetPropIndex (openProps,Constants.FS_AlertUserAboutFailure);
    openProps.propVal.ival=false;
Paul, Can you post the code that you are currently using? Thanks. -Rick
Rick, Here's a simplified version of the code:
     var openParams = GetOpenDefaultParams();
     var i = GetPropIndex(Constants.FS_MakeVisible, paramType);
     openParams.propVal.ival = 0;
     var path = "D:/MyOldFrameFile.fm";
     var doc = Open(path, openParams, returnParamOpen);
     if(doc.ObjectValid() == true)
        // If we successfully opened the doc then save as XML and then close
        // NOTE: Removed this code since it never gets here on the older 5.5 docs....
     else
        $.writeln("Couldn't open the file: \n" + path + "\n");
    i=GetPropIndex (openProps,Constants.FS_MakeVisible);
    openProps.propVal.ival=visible;
    i=GetPropIndex (openProps,Constants.FS_FileIsOldVersion);
    openProps.propVal.ival=Constants.FV_DoOK;
    i=GetPropIndex (openProps,Constants.FS_FileIsInUse);
    openProps.propVal.ival=Constants.FV_ResetLockAndContinue;
    i=GetPropIndex (openProps,Constants.FS_FontChangedMetric);
    i=GetPropIndex (openProps,Constants.FS_FontNotFoundInCatalog);
    i=GetPropIndex (openProps,Constants.FS_FontNotFoundInDoc);
    i=GetPropIndex (openProps,Constants.FS_RefFileNotFound);
    openProps.propVal.ival=Constants.FV_AllowAllRefFilesUnFindable;
    if (structuredApplication !== undefined) {
        i=GetPropIndex (openProps,Constants.FS_StructuredOpenApplication);
        openProps.propVal.sval=structuredApplication;
    // Attempt to open the document.
    docOrBook = Open (filename,openProps,retParm);
    if (docOrBook.ObjectValid () === 1) {
        // Add a property to the document or book, indicating that the script opened it.
        docOrBook.openedByScript = true;
    else {
        // If the document can't be open, print the errors to the Console.
        PrintOpenStatus (retParm);
    return docOrBook; // Return the document  or book object.
This is a general purpose function for opening documents or books. You can call it like this:
var doc = openDocOrBook (filename, structuredApplication, visible);
For structured documents, you can pass in a structured application name as the second parameter. For unstructured documents, just use undefined for the second parameter. The "visible" parameter can be 0 (open the document invisibly) or 1 (open the document and make it visible). Please let me know if you have any questions or comments.
Rick
Thank you Rick...  This did the trick!
