Hello Rick,
I hope all is well.
Great link you provided! (re: https://admin.adobe.acrobat.com/_a295153/microphones). I hadn't seen this one before.
Thank you.
I just ordered a Plantronics .Audio 750 DSP USB PC headset. A client did voiceover with it (which I incorporated into a CP4 project) and the sound quality was excellent with no background noise. Usually I have to clean up audio and remove white noise but this headset has noise-cancellation that seems to be really effective.
Hello, I studied audio recording engineering a couple of dozen moons ago so I am a bit of a mic snob and balanced cable snob. Having said that, I am pleasantly surprised and pleased with the reasonable pick up and good sound quality of the Logitech USB microphone (http://www.logitech.com/index.cfm/webcam_communications/microphones/devices/221&cl=us,en). It is only $29.00.... and used mics worth more than $500 in the past. It is certainly no Shure or Sennheiser but it is pretty good in a quiet, sound dampened environment.
Contrary to what an esteemed member of our group stated, I would actually recommend a USB microphone over a analog one because you will (or should) greatly reduce noise (professional microphones exempted). As long as the mic is recognized by Windows, Captivate theoretically should not care what type of mic is being used. I haven't experienced any issues but perhaps others have for some odd reasons.
I attached a list of best practices... a document I have been working on for a little while. It is based on my past experiences... although many entries were shamelessly ripped from other Internet pages. I hope this helps you archive the best possible recordings.
I had that one as well but found that it captured too much white noise if
you don't have a "dead" room in which to record. I recently got the Plantronics
.Audio 750 DSP USB PC headset which has great noise-cancellation. Because of
the headset form, you can get consistent distance from the mic each time
too.
Hi Shawn
I'm assuming you are referring to posts from five years ago. Back then we saw all manner of trouble with USB microphones in Captivate. Most often, Captivate had real problems sensing them while every other application on the PC found them just fine.
I think that may have been version 1 or 2. I don't recall. But there has been progress made since that time where it's no longer a big deal. I use and also would now recommend the USB type of microphone!
Also appreciate your sharing what you find to be the case with the Logitech. My typical mic setup is a Microsoft LifeChat USB. And I really like the results I get with it.
Cheers all... Rick
Helpful and Handy Links Captivate Wish Form/Bug Reporting Form |
Greetings Rick,
LOL... I now see that this thread is one of those long life ones. I did not notice that your comments about USB were from three years ago. 🙂
I also agree with the other commenter about the Logitech picking up white noise (or simply ambient noise). In order to record successfully with this microphone, you absolutely need proper sound dampening (see my attachment for some suggestions).
Also, I am not a big fan of microphones with built-in noise cancelling, in my experience they can introduce some undesired sound artifacts.
Strange.... I am posting as shawninvancouver and shawninvancouver2.... darn corporate and personal accounts cannot be merged. 😞
