Cross-references in printed doc
Jan 03, 2008 Jan 03, 2008
I am thinking about converting a FrameMaker book to RoboHelp, where I can generate it as CHM or PDF. But I don't want to lose the page numbers in cross references. RoboHelp seems to convert them to hyperlinks, which are included in the resulting printed documentation (DOC). But I would really like to include page number references as well in the final PDF. Has anyone found a way to do this?
798
Jan 04, 2008 Jan 04, 2008
Welcome to the forum.
First I don't think anyone has found a way of doing this. It would require a clever macro in Word. I have posted a question on my favourite Word forum and will post back if I get any response. So far though there are no takers, not a good sign as it is a forum that usually gets quick responses.
Post your requirement here.
http://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
Participant ,
There's no easy way to do this. RH doesn't include any sequence that will convert to a cross-reference in Word, and inserting multiple cross-references in Word isn't as easy as executing a find-and-replace command. The best workaround I've found so far is this:
1. In your RH doc, include a reference that is easily distinguished from other text. For example, "For information on Project Beta, see page BETA."
2. Generate the Word document.
3. Find the first instance of "BETA."
4. Insert a cross-reference to the page number of the Beta heading.
5. Toggle the field code.
6. Copy the field.
7. Find the next instance of your special text ("BETA" in this example).
8. Paste the field reference.
9. Repeat this process until you're finished.
Unfortunately, the field code references change each time you generate the document. Equally unfortunately, Word won't recognize regular braces and text as a field code reference - you have to use the Ctrl+F9 sequence to generate them manually. So you can't just generate the document, insert the first cross-reference, and then replace "BETA" with {PAGEREF _Ref### \h} across your entire document - it won't work. Instead, you must visit each reference and paste the field code sequence manually.
If someone else can improve on this process, I'm sure a lot of people would be happy. If not, it's the easiest workaround I've seen here, so you might find it useful.
Are either of you guys proficient with Word macros?
I've been sent something which I am told needs a bit of tweaking but should convert hyperlinks to cross references. Haven't tried it yet.
Please contact me via my site if you can help.
Participant ,
Only the basics, I'm afraid. Nowhere near "proficient."
Jan 05, 2008 Jan 05, 2008
Woo hoo!
I think we have a macro that does the job.
http://www.grainge.org/pages/authoring/word/word_macros.htm
Please let me know how well it works for you.
Jan 07, 2008 Jan 07, 2008
Wow, that works great! Thank you so much.
We try hard to please on this forum.
You need to check your text after running the macro as you might find one or two places where it is not quite right. For example, you have a link followed by something in brackets, now you will have two things in brackets.
Also you may have some unwanted double spaces but that's soon fixed.
Participant ,
*bump*
I haven't tried the macro yet, but I'm surprised at the lack of response to this posted solution despite the large number of requests for such a feature.
Perhaps if I priced the download at $10, people would queue for it. They just don't believe it can work if it's free.
When I worked in a bank, one of my managers had a customer who was going broke for lack of business. He looked staggered when told to increase his prices. He did and went from success to success. Nobody thought he was any good when his prices were cheap!
Jan 13, 2008 Jan 13, 2008
I've made a small change to the macro which removes the space problem.
Either download it again or edit it in Word. Go to the second r.InsertAfter Text and amend it from
to
Removing that space makes it work correctly, at least in my documents!
RoboHelp Documentation
Download Adobe RoboHelp
