Stripping
Participant ,
Jan 04, 2008 Jan 04, 2008
Hello.
I am pulling chunks of html code and only want to display a snippet of the chunk - the image mainly.
Here is what I am currently pulling:
<p><a href=" http://www.yahoo.com">Yahoo!</a> news:</p>
<p><a href=" http://www.yahoo.com/story/2166317809/" title="Test"><img src=" http://server3.static.yahoo.com/2378/2166317809_10a0c4_m.jpg" width="240" height="160" alt="Test" /></a></p>
I want to end up with just this:
I have done something along the same lines with an image path (I stripped off the characters after the second . ) but I was wondering how to do it with this longer string.
Any ideas?
Advanced techniques
537
Valorous Hero ,
Try using a regular expression. Though not the best, something along these lines
Participant ,
Ok can you step me through that?
Valorous Hero ,
The function uses 4 parameters:
reFindNoCase( theRegularExpression, theString, startAtCharacter, returnSubExpressions)
If you break down the regular expression <img[^>]+>:
The first part finds the start of an image tag: <img
Followed by one or more characters that are not the closing tag: [^>]+
Followed by the closing tag: >
When you set returnSubExpressions to true, the result is an array containing the starting position and length of the matched string: ie result.pos[1] and result.len[1]. You can use those values, with the MID function, to obtain the matched substring.
<cfset matchedSubstring = Mid(chunkOfHTML, result.pos[1], result.len[1])>
Participant ,
Brilliant
Participant ,
Jan 05, 2008 Jan 05, 2008
How do I output the variable the has the html stored so the browser interprets it as the actual html instead of just outputting the literal value.
Valorous Hero ,
Just remove the <pre> tags and HTMLEditFormat and it should behave as html.
<cfoutput>#newString#</cfoutput>
Participant ,
Yep that's it. Thanks again!
Participant ,
Jan 17, 2008 Jan 17, 2008
How about this one?
I am pulling in a friend's forum rss feed and we are trying to figure out how to make images display correctly. When people post images on his forum, they don't post correctly when I pull the feed. Here is a sample chunk that I pull in:
I am posting a forum image here... Image: http://mysite/test.jpg
How would I be able to make the "Image: http://mysite/test.jpg" update to <img src=" http://mysite/test.jpg">
TIA
Valorous Hero ,
Jan 20, 2008 Jan 20, 2008
Sorry I did not respond. The forums appeared to be down. Did you get this sorted out yet?
(Btw, you have PM disabled)
Participant ,
I finally just buckled down and read some tutorials about it. I am getting a decent grasp on it, but still have some trouble translating some of the more advanced regex code. I will enable PM.
Cheers!
Engaged ,
As an aside, to test you regex and refine it I would like to recommend Regex Coach http://www.weitz.de/regex-coach/ it is really super helpful!
Documentation
