hello:
i have a problem with a movieclip named 'notes' that is loop without stop , i added the script stop(); for it but he didn't stop.
this is the Movieclip 'note_mc ' that trigger the movieclip 'notes'.
and this is the 'notes' Movieclip that looping witout stop.
this is the code source for more information you can download it and you can found the code source under the folder :English Version/animations/en_hz000254.fla
http://www.mediafire.com/download/g913lubogrrqaid/English+Version.rar
and thank you in advance
did you add a stop() to the 'notes' movieclip timeline?
if so, does the frame that contains notes (ie, on notes parent's timeline) play more than once?
thank you for you reply ,
yes i have edded the stop , this is image below illustrate what is the action script of the first frame in the movieclip
i have a noticed one think that when i remove the MASK with the layer named '2' the probleme of repetitive animatin gone and i got the needed result
1. that's not as3. it's as2
2. that code is on, what looks like, sorte 415's timeline, but it's hard to tell. i'm not sure if that's note_mc's timeline.
3. show the timeline that contains notes_mc and indicate which layer contains notes. (and make sure its the only object on its layer.)
