Bringing the active table under focus when script is interrupted by a dialog box
Jun 30, 2015 Jun 30, 2015
I have customized a script that browse tables into a Fm file and prompt the user if he wants the current active table to be reformated or not
I haven't find a clean way to have the table that is currently selected in the variable "tbl" to be visible on the screen when the scripts sends a dialog.
The workaround that I have found consists in starting some formating on the table before sending the prompt, in that case the currently processed table is visible when the prompt arises.
But I would like to have the table visible and avoid doing any processing on the table before the user has had a chance to answer the prompt.
I assume there must be a method to bring the focus of the active window on an element that is selected in a variable?
function ApplyTableFormat(doc)
    if (doc.ObjectValid())
        var tbl = doc.SelectedTbl
        var tbltitle;
        var tblTextItem;
        while (tbl.ObjectValid())
            tbltitle = "";
            tblTextItem = tbl.FirstPgf.GetText(Constants.FTI_String);
              for (var i = 0 ; i < tblTextItem.length; i++)
                   tbltitle += tblTextItem.sdata ;
            /* How to make my "tbl" visible in the active doc window ? */
            if(Alert("Formating: " + tbl.FirstPgf.PgfNumber + tbltitle +" ?\nClick cancel to abort.",Constants.FF_ALERT_CANCEL_DEFAULT))
                 return;
            /* insert table formating code here */
            tbl = tbl.NextTblInDoc;
    else
      Alert ("No active doc" ,Constants.FF_ALERT_CONTINUE_WARN)
      return
Scripting
242
Community Expert , Jun 30, 2015 Jun 30, 2015
There is a document function that will scroll the window to a particular text location:
doc.ScrollToText (textRange);
You might be able to do something like this:
doc.ScrollToText (new TextRange (tbl.TextLoc, tbl.TextLoc));
-Rick
-Rick
Jul 01, 2015 Jul 01, 2015
Thank you Rick!
