I have tried everything to update the Flash player, including the clean install procedure.
I have had my hardware/Windows 7 64-bit configuration through many iterations of Flash Player. But, I cannot get past "Installation Failed" for version 18.0.0.194 no matter how many times I have tried. Flash is not on my system since I removed it completely following the clean install procedure.
What can I do? I'm not doing a clean install of Windows simply to address this problem.
Hi Nicholas,
Please follow the steps mentioned in the below document.
Uninstall Flash Player | Windows
Devendra
Hi pernick61,
Try restarting your system if you haven't done so.
If that doesn't work please feel free to uninstall flash player using Uninstall Flash Player | Windows and install using Flash Player for your browser from page - Installation problems | Flash Player | Windows
Piyush
Thanks for the replies. But, as I noted in my post, I have tried these steps. My system has no trace of Flash as I followed the steps to completely remove Flash. Checking for Flash, I am reassured that: "Sorry, Flash Player is either not installed or not enabled."
I have restarted several times since removing Flash and, once in a while, I have attempted to install Flash but I invariably get "Installation Failed".
Are there a registry values I need to concern myself with? The steps for removing Flash only involve deleted files.
Omigosh. Ran the flash installation file once more and, voila!
I really want to ditch these electronic gizmos and go back to an Etch-a-Sketch. That and dixie cups and string. SIgh.
Thanks to all.
Great
