I buy a book and when I download it, I get an URLLink.acsm files. When I want to open it, ADE gives a message "Error ! Check activation"
What does I do ?
Hello!
This means that your new e-book is DRM protected. You probably need to authorize the device you want to view the book on. To do that, you need an Adobe ID. Since you are posting in these forums, you already have Adobe ID.
1. Start Adobe Digital Editions.
2. Press Ctrl+Shift+U.
3. Follow onscreen instructions.
I am assuming you are a Windows user. Is that correct? For a Mac, the keyboard shortcut should be Cmd+Shift+U. You can of course also go to the program menu Help, and then "Authorize Comptuer".
Have you been reading the book on any other device yet? There are different "eBook vendors". If you got your book from Google, then I suggest you use your Google account to authorize your computer via Adobe Digital Editions, and not your Adobe ID.
Thank you for your answer. My computer was already authorized to read the book. I've already download ohters ebooks before and didn't have any problem. The only difference is the Adobe Digital Edition's version. Before, I have ADE v2.? (Sorry, I don't remember) and now I have the 4.03 version.
So I can't download the ebook 😞
Hi, i have the same problem with the 4.03 version. I´ve tried use crtl+shift+U and nothing happens. My device is a wibook from inves, i´m running windows 7. What an i do? thanks
For this problem, you need to deauthorize and authorize ADE again.
Launch ADE
Help -> Erase authorization.
ADE will be deauhorized.
Now again AUTHORIZE ADE
Help-> authorize computer.
Error will be fixed !!
I have the same problem, but when I go to de-activate it tells me "unable to erase - try again after sometime". Well I waited 2 days - and I still get the message - Help!mess
I also got the error! Check activation message - tried the ctrl shift u - it did nothing for me either..
If due to some reason, you are unable to deauthorize ADE, follow the below steps:
Mac: Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
ADE will be deauthorized now.
Now Authorize ADE again.
Windows:
Choose Start > Run.
In the Open text box, type regedit and then press Enter. The Registry Editor opens.
In the left pane of the Registry Editor, locate the following registry key:
HKEY_CURRENT_USER\Software\Adobe\Adept
Right-click the Adept key and choose Delete.
In the Confirm Key Delete dialog, click OK.
Your authorization will be deleted.
Reference:
https://helpx.adobe.com/digital-editions/kb/error-e_act_not_ready.html
Thanks a lot!!!, you solve my problem.
Well that didn’t work for me – but I’ll have my husband try again tonight – he is better with computers than I am. I’ll keep you posted and I appreciate your help.
Thanks - Debbie
I tried for ! two days and you save me
thanks a lot !!
Ok – my husband tried and he got farther than I did – he was able to re-authorize, but even after re-authorizing when we go to open a book we still get the Error! Check activation message…
Any other ideas??
Please deauthorize and authorize using latest version of ADE (4.0.3)
Thanks !!
I’ve tried several times and I still get the unable to deauthorize error that I got before…. ☹
Hi I posted a similar problem before I checked this posting (oops!). Anyway, this seemed to solve my problem of "Error: Check Activation". Thanks!!
Hey,
I cannot find this registry key. I'm using Windows. Digital Editions tells me that my Computer is authorized already, but I'm not able to erase authorization. What can I do? Any idea?
Thanks a lot for answering.
Hello,
Please download the latest ADE 4.0.3.117585
http://www.adobe.com/solutions/ebook/digital-editions/download.html
Launch ADE
Your error will be fixed.
Thanks for being the part of product improvement.
I have already installed this version of Adobe Digital Editions.
I have exactly the same problem as nicolep... and bertafw
I allready installed the latest version of ADE, I made every manipulation shreya wrote, but I always recieve the same message "Error! check activation"
Help me PLEASE, I become crazy with this software !
Thank U !
I'm not certain I can help you. Note that the terms "authorization" and "activation" are used interchangeably. You followed Shreya'a steps, if using Windows you ran Regedit and deleted the cited key (folder) entitled "Adept". Now start ADE 4 and look on the Help menu. If the "Authorization Info" menu item is greyed out, ie. disabled, then you have successfully removed your existing authorization and so the message "error check activation" is truly correct and expected. You of course have to go back to that Help menu and choose "Authorize this machine/device". Be sure you know your correct Adobe ID and password.
Yeah this danged software drove ME totally bazonkers for a couple/three days. I was at wits end. And when the problem finally got resolved I didn't even know how or why it finally got working again. Post again with any new information or error messages received and BEST OF LUCK TO YOU!
Thanks a lot!! I can solve this problem.
Thanx a lot! You are the only one who really helped.
Thank you!!!
there is no erase autorization option for me to click
I was able to delete in regedit screen but wont let me authorize. same error message
It worked for me, thanks!
