I want the chapter title to appear in the header, so I am using the <$chaptertitlename> tag in a running header variable show the file name. However, the file's suffix .fm also appears. How can I remove the suffix?
Interesting… I thought I'd done this once with a <$shortfilename> variable, but when I check before posting :-} it seems that variable doesn't exist. The "About variables" page in the Adobe help is particularly opaque, too. I'll watch and learn.
re: However, the file's suffix .fm also appears. How can I remove the suffix?
Unless FM versions later than I've used provide some new way, you can't.
See hack in Re: System Variables
Just out of interest, what is <$chaptertitlename> intended to deliver that <$filename> doesn't? as I said, I found the Adobe help page on variables particularly unenlightening. (and the concept the name of the title of the chapter sounds like something dreamt up by Humpty-Dumpty in "Through the Looking-glass" … but perhaps I'm just being picky)
