Generated output has no TOC, index or Search in IE11, doesn't appear in Chrome, works fine in Firefox
Jun 30, 2015 Jun 30, 2015
Hello all,
This is an old and working HTML project. I published it yesterday, it has been revised and now, when I'm doing my changes and I generate locally to see the changes by clicking View Result, it launches IE by default with nothing in the TOC/Index/Search area, although the contents of the index.htm appear. There is an error window titled Message from webpage that says Error reading masterData.xml. The only file I see in the generated output that starts masterData is MasterData_xml.js.
Only thing that is different about this morning versus other mornings: my machine rebooted overnight with RH and the project open. I had saved all my work though so that at least is ok!
Anyone have any ideas for me? It's a merged project that is currently working where it is published, but I need to make changes pretty quickly!
TatuMbili
304
By the way, as it says in the title, when I launch in Chrome, nothing happens, nothing opens. Launched in Firefox, it works like a charm!!
Thanks.
Some version numbers would help. Versions of Rh and the browsers.
@petergrainge
RoboHelp 10, IE11, Chrome 43.0.2357.130 m and Firefox 33.1.1. I've been using IE and in fact, have the published version working on it right now, it's just when I open the changed locally generated version I get the errors.
If it helps any, the breadcrumbs aren't working either, not hyperlinked and they don't have a Home link.
Thanks.
Helen
Jul 01, 2015 Jul 01, 2015
In your output, is there a masterData_js.xml present or is it missing? Where do you see the error? In a popup or somewhere else?
There is a  MasterData_xml.js file but not masterData.xml as referred to in the popup error window nor is there masterData_js.xml that you asked for.
I came across this posting which seemed on point: RH 10 generating webhelp viewing with IE11 - Error reading masterData.xml so I regenerated without MOTW, I had a TOC, then I clicked on the Allow blocked content at the bottom, error popped up again and the TOC disappeared. I had been able to navigate through the TOC before I clicked on the blocked content message.
I've also done this: RoboHelp output issues | IE 11 and re-installed the .js files. No change. Then I unticked MOTW and regenerated again, it works but you get that stupid message to Allow Blocked Content at the bottom, but only on the first page. I don't want the message: does all this help with any suggestions?
Helen
Jul 06, 2015 Jul 06, 2015
The 'Allow Blocked Content' message is to be expected when you open the help locally with Internet Explorer. As soon as you post the content on a web server, you won't get this issue. You'll simply have to live with this for local help.
Does the JS fix fix the original error? I'm not entirely clear on that.
No, the JS fix did not fix the error. As far as I can see, it was the unticked MOTW which did the trick. I'm not really happy with not using MOTW and don't understand why it would have worked before when it was ticked and now it doesn't. I haven't made any change in RH that should have done it, just content changes. I know my computer did a company-generated update the previous night, maybe it's just my settings somewhere.
BTW, when published to the web server, everything works properly, including Chrome. I still can't launch the local generated product in Chrome but I guess that's another question.
Helen
There were a number of fixes issued for RH10 to get around browser security issues – check out Willam’s site for a summary of patches.
RoboHelp Documentation
Download Adobe RoboHelp
