I have windows XP..and use Firefox(the plug-in works fine)....I have tried everything......keeps saying Adobe download manager has encountered a problem and needs to close....tried all the offline links,does the same thing
Hi catniprosesā,
Try restarting your system if you haven't done so.
If that doesn't work please feel free to uninstall flash player using Uninstall Flash Player | Windows and install using Flash Player for your browser from page - Installation problems | Flash Player | Windows
Piyush
It says I need this:
System requirements
But I have this:
AMD Athlon(tm) 64 X2 Dual Core Processor 3800+ 1.99 GHz, 896 RAM
Can I update Adobe Flash Player?
I did finally uninstall the flash player thinking I could just reinstall it.....didn't work......keeps giving me "the Adobe download manager has encountered a problem and must close". It also says that when I try to update my Adobe Reader also....I just cannot figure out why the Adobe download manager has anything to do with it all of a sudden....It's been doing updates fine up till now....
I went here:
and I choose this site for installation in Firefox:
http://fpdownload.macromedia.com/pub/flashplayer/latest/help/install_flash_player.exe
those links give me the firefox plug in.......doesn't help me if I want it on my harddrive.....can't run Incredimail without it.....thnks tho
What should I do?
Hi catniproses,
Well,
Grab the Uninstaller here:
http://download.macromedia.com/get/flashplayer/current/support/uninstall_flash_player.exe
run it; it will uninstall ALL flash player versions
Next let make sure you have the correct processes closed.
Open a CMD prompt Run a Command as Administrator from the Windows 7 / Vista Run box
copy/paste the following one by one or make a bat file to do it all in one step How to Write a Batch File (with Examples) - wikiHow
taskkill.exe /im plugin-container.exe /f
taskkill.exe /im firefox.exe /f
taskkill.exe /im iexplore.exe /f
taskkill.exe /im flash* /f
taskkill.exe /im battle* /f
That should close any flash dependent programs ( that I know of )
next in the cmd window do the following:
ATTRIB -H -S -R C:\Windows\System32\Macromed\Flash /s /d
ATTRIB -H -S -R C:\Windows\SysWOW64\Macromed\Flash /s /d
rmdir "C:\Windows\System32\Macromed\Flash" /s /q
rmdir "C:\Users\%username%\AppData\Roaming\Adobe\Flash Player" /s /q
rmdir "C:\Users\%username%\AppData\Roaming\Macromedia\Flash Player" /s /q
IF exist C:\Windows\SysWOW64 rmdir "C:\Windows\SysWOW64\Macromed\Flash" /s /q
( note IF you are on 32 bit you can eliminate anything with sysWOW64 )
Next try installing the files at the bottom of this page one by one.
Hopefully that will get you up and running. ( why Adobe does not provide a bat file and automate it is beyond me to simplify it for end users)
Good luck
Piyush
