When I try to run the installer for flashplayer 18 on Windows XP, I get "Adobe Download Manager has encountered a problem and needs to close. We are sorry for the inconvenience." I have downloaded a fresh copy with the same result. The file is called:
flashplayer18_ha_install.exe
I am using Firefox and sometimes Chrome, both of which report flash player needed updating.
Mandy
Don't use the download manager, use the offline installers
Hi pwillener,
I have the exact problem described above (Windows XP, Adobe Flash Player 18 update) for installing latest update - and I use the offline installer. I even uninstalled Flash Player after reading your post and then re installed (Firefox version). Same result as described by mandyw. I uninstalled the Download Manager as well and still it says "Adobe Download Manager has encountered a problem and needs to close. We are sorry for the inconvenience" so that made no difference at all.
I now have a message at the top of nearly every page I open in Firefox saying that Adobe plugin is unstable and Firefox has therefore disabled it, and I need to manually agree to run the player on every page or download the latest update - which fails as described above. So I'm completely stuck here.
Hi
Well, this might look like a big solution but its a small one.
Try this
Grab the Uninstaller here:
http://download.macromedia.com/get/flashplayer/current/support/uninstall_flash_player.exe
run it; it will uninstall ALL flash player versions
Next let make sure you have the correct processes closed.
Open a CMD prompt Run a Command as Administrator from the Windows 7 / Vista Run box
copy/paste the following one by one or make a bat file to do it all in one step How to Write a Batch File (with Examples) - wikiHow
taskkill.exe /im plugin-container.exe /f
taskkill.exe /im firefox.exe /f
taskkill.exe /im iexplore.exe /f
taskkill.exe /im flash* /f
taskkill.exe /im battle* /f
That should close any flash dependent programs ( that I know of )
next in the cmd window do the following:
ATTRIB -H -S -R C:\Windows\System32\Macromed\Flash /s /d
ATTRIB -H -S -R C:\Windows\SysWOW64\Macromed\Flash /s /d
rmdir "C:\Windows\System32\Macromed\Flash" /s /q
rmdir "C:\Users\%username%\AppData\Roaming\Adobe\Flash Player" /s /q
rmdir "C:\Users\%username%\AppData\Roaming\Macromedia\Flash Player" /s /q
IF exist C:\Windows\SysWOW64 rmdir "C:\Windows\SysWOW64\Macromed\Flash" /s /q
( note IF you are on 32 bit you can eliminate anything with sysWOW64 )
Next try installing the files at the bottom of this page one by one.
Installation problems | Flash Player | Windows
Hopefully that will get you up and running. ( why Adobe does not provide a bat file like i have and automate it is beyond me to simplify it for end users)
Good luck
Hi
Yes, this does seem very complicated and scary for someone who knows zero about computers!!
Regarding:
I have windows XP (see first line of post) and this seems to be for Vista or Windows 7?
Hi
I have got the latest version now, but not through the updates which still don't work.
Flash Player for Firefox - NPAPI has suddenly changed to the latest version 18.0.0.194 (it was still the old one until this morning) and I have downloaded it and installed with no problems.
You genius.
Thank you
I forgot to say that you can get the latest version of Flash Player for Firefox (and other browsers too) at the bottom of this page, under "Still having problems?" heading:
That is where I got it from.
