I lost a sequence in Adobe Premiere Pro CC. I was going to export a new sequence I created in a project. While I was doing it, the PC crashed.When I restarted premiere, my updated project file was gone and only an older version opened, where all my work was missing. Does anybodu have an idea what I can do?
Thank you very much. But the problem is solved. I found the timeline.:-)
Moving this post to Premiere Pro forum.
how?
I lost my sequence.
Double click it in the Project Panel.
I'm fairly new to Premiere. When you say double click it in the project panel. where is that?
PeruBob means double click on the sequence in the Project Window.
Yeah, this DIDN'T WORK FOR ME EITHER!!!!
Try auto save. Maybe you did delete it from your project.
thank you so much!!!!! u saved my life
I clicked a random audio track i had added before i deleted my sequence, and it brought up my old sequence again.
I finally found my main sequence inside of the footage folder. If your sequence was created by dragging footage into the timeline, that sequence file SHOULD be in the same directory as that said footage.
It is.
