Locked
Your binary is not optimized for iPhone 5, Application Loader, ERROR
Jul 04, 2015 Jul 04, 2015
I am using flash builder 4.6 , Air 18.0 on windows 7.
I am receiving error.
Your binary is not optimized for iPhone 5 - - New iPhone apps and app updates submitted must support the 4-inch display on iPhone 5 and must include a launch image with the -568h size modifier immediately following the <basename> portion of the launch image's filename. Launch images must be PNG files and located at the top-level of your bundle, or provided within each .lproj folder if you localize your launch images. Learn more about iPhone 5 support and app launch images by reviewing the 'iOS Human Interface Guidelines' at 'https://developer.apple.com/library/ios/documentation/UserExperience/Conceptual/MobileHIG/ IconsImag...' and the 'iOS App Programming Guide' at 'https://developer.apple.com/library/ios/documentation/iPhone/Conceptual/iPhoneOSProgrammin gGuide/Ap...'.
I packed all type of style one by one Default-568h@2x.png Default.png, Default-568h@2x~iPhone.png etc but eror is not going.
what i do to remove error. I packed up images and images one by one on splashimage... default page.
Now i am confuse may be this is Air error or apple error, or my flash builder error.
please can you assit.
with regards.
Naser.
832
Engaged , Jul 06, 2015 Jul 06, 2015
Default-568h@2x.png is the required filesize, and it must have dimensions of 640x1136.
Make sure this file is included in your IPA in the top level directory.  A good way to check is to rename "myapp.ipa" to "myapp.zip" and unzip it and look for it in the top level of the folder structure.
To get Flash Builder to include it in the IPA, put it in a folder that is included in your flash builder source tree (I use the folder "system" and make sure it's added separately to the project), and make sure
Engaged ,
To get Flash Builder to include it in the IPA, put it in a folder that is included in your flash builder source tree (I use the folder "system" and make sure it's added separately to the project), and make sure you have it checked in the package contents box:
Also, make sure you have "copy non-embedded files to output folder" checked on this screen:
Hope that helps!
thanks for help. it is ok now.
Engaged ,
glad to help!
