      • EspaƱol
      • FranƧais
      • PortuguĆŖs
  • ę—„ęœ¬čŖžć‚³ćƒŸćƒ„ćƒ‹ćƒ†ć‚£
  • ķ•œźµ­ ģ»¤ė®¤ė‹ˆķ‹°
Locked
Does any one know how to get rid of the management action "upgrade adobe flash" pop up window. Im on 10.5.8 (mac) and already upgraded as far as it goes?
Jul 07, 2015 Jul 07, 2015
2.6K
Community Beginner , Jul 08, 2015 Jul 08, 2015
Found out that this particular message is being sent out by jamfhelper  part of our casper suite. Thanks all for  your assistance
Adobe Employee ,
Hi Mark,
Can you please post a screenshot of the same?
Sheena
Adobe Employee ,
Moving this discussion to the Installing Flash Player forum.
Adobe Employee ,
Hi Mark,
This is an update for the Flash player.
It is required for the browsers you run.
Refer: Flash Player | Adobe Flash Player | Overview
Sheena
considering OS 10.5.8 can't run any higher than version 10.3  I'm pretty sure it cant be upgraded. How do i stop the notification
Adobe Employee ,
Hi markl40635404,
That pop-up dialog window is not a Flash Player update notification dialog window.  Flash Player update dialog window looks different and it would state 'Adobe Flash Player' not 'Adobe Flash'. I've not seen this particular window before and am not familiar with it. Is this something that started popping up recently on your system?
To disable Flash Player update notifications do one of the following:
  • Select the 'Never check for updates (not recommended)' radio button in the Flash Player preference (in your screenshot)
  • Edit the mms.cfg file located at /Library/Application Support/Macromedia and set AutoUpdateDisable=1
Since you're processor is Intel (instead of PPC) you may be able to upgrade to OS X 10.6, which would allow you to install the latest version of Flash Player.  There is quite a bit of information on the internet about this (searching for 'upgrade OS X 10.5 to 10.6).
Maria
unfortunately these machines cant be upgraded due to configuration of other software. The first report I had of it was 7/2/15. I'll try the mms cfg file.
Adobe Employee ,
Hi markl40635404,
To reiterate, this is not a Flash Player dialog window.  Ensuring Flash Player updates is disabled in the mms.cfg file will just ensure that Flash Player doesn't check for an update and that the real Flash Player update notification dialog window doesn't display.  Which is your desired outcome.
I suspect you have some other software installed on the system that is triggering this dialog window.  I would check the system log files to see if there's anything recorded there at the time this dialog window popped up.  It may give you a clue as to what is triggering this dialog window.
Maria
I'm having this same issue.  I uninstalled Adobe and reinstalled 10.3
I have the exact same OS, processor and RAM as Mark.  The message also started popping up around the start of the month.  I did not install any new software.
Adobe Employee ,
Hi markl40635404,
Thanks for updating the thread with the source of the message.  Hopefully it'll help others experiencing the same behaviour.
Maria
