The msi on Adobe Flash Player Distribution | Adobe is still version 18.0.0.194. When will this be fixed?
I flushed the IE cache and deleted all IE settings. Re-downloaded it and got a 1722 error when attempting to install. The exe works fine but I need the msi.
Seems to only be the ActiveX download. The Plugin msi installs the correct version.
That is what i am seeing as well.
@core34,
Please provide the following log files using the instructions posted here How to share a document.
You're issue appears to be different from the OP, so I branched you're previous comment into a new thread, SCUP Download: "The operation has timed out." error downloading MSI installer. Based on the information provided, the OP is able to download but the installation is failing, while the information you provided stated "Download file: https://fpdownload.macromedia.com/pub/flashplayer/current/licensing/win/install_flash_play er_18_act... failed with message "The operation has timed out."".
Please reply to the other thread so that all posts pertaining to your issue are in one place.
Thank you.
Maria
The cloud says it's currently unavailable.
2015-7-8+18-8-41.673 [error] 1226 1062
=O====== M/18.0.0.194 2015-07-08+18-08-35.828 ========
0000 00000010 "C:\Users\OrrCM\AppData\Local\Temp\InstallAX_18_0_0_194.exe" -install -msi
0001
0002
0003 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
0004
0005 00000013
0006 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_18_0_0_194_ActiveX.exe
0007 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_18_0_0_194_ActiveX.dll
0008 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0009 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0010
0011
0012 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0013
0014
0015
0016 00000012
=X====== M/18.0.0.194 2015-07-08+18-08-44.510 ========
=O====== M/18.0.0.194 2015-07-08+18-22-46.265 ========
0000 00000010 C:\Windows\system32\Macromed\Flash\FlashUtil32_18_0_0_194_ActiveX.exe -uninstall activex -msi
0001
0002
0003 00000018
0004
0005
0006 00000018
0007
0008
0009 00000018
0010
0011
0012
0013
0014
0015
0016
0017
0018
0019
0020
0021
0022
0023 00000018
0024
0025
0026
0027
0028
0029 00000012
=X====== M/18.0.0.194 2015-07-08+18-22-46.508 ========
=O====== M/18.0.0.203 2015-07-08+18-23-15.344 ========
0000 00000010 "C:\Windows\system32\Macromed\Flash\FlashUtil32_18_0_0_203_ActiveX.exe" -refreshIEElevationPolicies
=X====== M/18.0.0.203 2015-07-08+18-23-15.353 ========
=O====== M/18.0.0.203 2015-07-08+18-23-05.465 ========
0000 00000010 "C:\Users\OrrCM\Downloads\install_flash_player_18_active_x.exe"
0001
0002
0003
0004
0005
0006
0007 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
0008
0009
0010 00000018
0011
0012 00000013
0013 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_18_0_0_203_ActiveX.exe
0014 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_18_0_0_203_ActiveX.dll
0015 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0016 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0017
0018
0019 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0020
0021
0022
=X====== M/18.0.0.203 2015-07-08+18-23-22.161 ========
=O====== M/18.0.0.203 2015-07-08+19-16-41.341 ========
0000 00000010 "C:\Windows\system32\Macromed\Flash\FlashUtil32_18_0_0_203_ActiveX.exe" -maintain activex
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011 00000018
0012
0013
0014 00000018
0015
0016
0017
0018
0019
0020
0021
0022
0023
0024
0025
0026
0027
0028
0029
0030
0031 00000012
=X====== M/18.0.0.203 2015-07-08+19-16-55.580 ========
=O====== M/18.0.0.194 2015-07-08+19-17-36.050 ========
0001
0002
0003
=X====== M/18.0.0.194 2015-07-08+19-17-39.035 ========
=O====== M/18.0.0.194 2015-07-08+19-18-16.828 ========
0001
0002
0003
=X====== M/18.0.0.194 2015-07-08+19-18-19.374 ========
=O====== M/18.0.0.194 2015-07-08+19-20-31.779 ========
0001
0002
0003
=X====== M/18.0.0.194 2015-07-08+19-20-34.843 ========
=O====== M/18.0.0.194 2015-07-08+19-23-18.607 ========
0001
0002
0003
=X====== M/18.0.0.194 2015-07-08+19-23-20.774 ========
=O====== M/18.0.0.194 2015-07-08+19-26-55.664 ========
0001
0002
0003
=X====== M/18.0.0.194 2015-07-08+19-26-57.909 ========
=O====== M/18.0.0.194 2015-07-08+19-30-36.361 ========
0001
0002
0003
=X====== M/18.0.0.194 2015-07-08+19-30-38.605 ========
=O====== M/18.0.0.194 2015-07-08+20-06-21.799 ========
0001
0002
0003
=X====== M/18.0.0.194 2015-07-08+20-06-24.149 ========
I downloaded the file from https://fpdownload.macromedia.com/pub/flashplayer/current/licensing/win/install_flash_play er_18_act... and it installed the correct version without an issue.
