Locked
download/save/run--connection failed windows 7, firefox 39.0
Jul 07, 2015 Jul 07, 2015
1.3K
Adobe Employee , Jul 07, 2015 Jul 07, 2015
Please exit your browser and download  Flash Player for Firefox - NPAPI . Install it.
Adobe Employee ,
Adobe Employee ,
Jul 08, 2015 Jul 08, 2015
Hi kz94b5‌,
Can you Please try following the Steps suggested in this Post by Carm01:
Well,
First please save all the work which is open on any browser because we'll be closing all of them.
Grab the Uninstaller here:
http://download.macromedia.com/get/flashplayer/current/support/uninstall_flash_player.exe
run it; it will uninstall ALL flash player versions
Next let make sure you have the correct processes closed.
Open a CMD prompt Run a Command as Administrator from the Windows 7 / Vista Run box
copy/paste the following one by one or make a bat file to do it all in one step How to Write a Batch File (with Examples) - wikiHow
taskkill.exe /im plugin-container.exe /f
taskkill.exe /im firefox.exe /f
taskkill.exe /im iexplore.exe /f
taskkill.exe /im flash* /f
taskkill.exe /im battle* /f
That should close any flash dependent programs ( that I know of )
next in the cmd window do the following:
ATTRIB -H -S -R C:\Windows\System32\Macromed\Flash /s /d
ATTRIB -H -S -R C:\Windows\SysWOW64\Macromed\Flash /s /d
rmdir "C:\Windows\System32\Macromed\Flash" /s /q
rmdir "C:\Users\%username%\AppData\Roaming\Adobe\Flash Player" /s /q
rmdir "C:\Users\%username%\AppData\Roaming\Macromedia\Flash Player" /s /q
IF exist C:\Windows\SysWOW64 rmdir "C:\Windows\SysWOW64\Macromed\Flash" /s /q
( note IF you are on 32 bit you can eliminate anything with sysWOW64 )
Next try installing the files at the bottom of this page one by one.
Installation problems | Flash Player | Windows‌
Also, Please ensure that your Anti-virus is turned off while uninstalling Flash Player.
Let us know if this works.
Piyush
suriti.singh <https://forums.adobe.com/people/suriti.singh> ’s method worked!!
Thanks anyway
I saw not the crest
Russ Lovick
<removed personal information>
Adobe Employee ,
Hi kz94b5,
I realize you've already installed Flash Player using the offline installer, however, I'd like to get the log files for the online installer that are resulting in this connection failed error to forward to the team that handles the online installer to troubleshoot further. The log files for the online installer are saved at C:\Users\YourUserID\AppData\Local\Temp\Adobe_ADMLogs.  Please upload both of the files in this directory using the instructions here How to share a document and post the link to the files in your reply.
Thank you very much.
Maria
Adobe Employee ,
Hi kz94b5,
Thanks for posting the log files for the online installer.  The online installer downloads and installs Flash Player silently in the background.  I'm seeing reference to a proxy server in the log file.  Do you have your computer configured to use a proxy server?  If so, how do you have it configured?
Thank you.
Maria
no proxy
I saw not the crest
Russ Lovick
Adobe Employee ,
Hi kz94b5,
Thanks for confirming.  Can you please do the following:
  • Launch Firefox
    • Go to Tools > Options > Advanced > Network
      • Alternatively, in the address field type: about:preferences#advanced then click the Network tab
    • In the Connection section, click the Settings button
    • Post a screenshot (see How to post a screenshot in the forum) of the Connection Settings window that displays
  • Launch IE
    • Go to Tools > Internet Options > Connections
    • click the LAN Settings button
    • Post a screenshot of the Local Area Network (LAN) Settings window that displays.
Thank you.
Maria
Jul 09, 2015 Jul 09, 2015
Hi kz94b5,
Based on logs it looks like your PC could not connect to internet at that time when installation was starting. Can you share the internet bandwidth/speed which you are using?
Anindya
no idea of bandwidth, speed was testing 30-40 mb/sec down, 2-4 mb up (brighthouse indianapolis in)
this error appeared over 2 months of trying to update flash--all previous updates occurred without issue
I saw not the crest
Russ Lovick
Jul 10, 2015 Jul 10, 2015
Thanks for the details. Can you give details if you have any anti-virus software running on your machine. Although Flash Player installer works with Anti-virus softwares but I have seen a case where Anti-cirus was conflicting. If possible can we have a screen share session with you at your convenient time to debug more and figure out the root cause. It should not take more than 15-20 minutes.
Anindya
Hi!
Screen share session will be fine but it will have to be next week as I am away from home for the weekend. I have Avira antivirus and had it disabled at the time I was trying to install.
Jennifer
Sent from Yahoo Mail on Android
Date:Fri, Jul 10, 2015 at 6:30 AM
Subject:[Installing Flash Player] download/save/run--connection failed  windows 7, firefox 39.0
created by AnindyaS in Installing Flash Player - View the full discussion
Anindya
If the reply above answers your question, please take a moment to mark this answer as correct by visiting: https://forums.adobe.com/message/7741194#7741194 and clicking ‘Correct’ below the answer
Replies to this message go to everyone subscribed to this thread, not directly to the person who posted the message. To post a reply, either reply to this email or visit the message page:
Please note that the Adobe Forums do not accept email attachments. If you want to embed an image in your message please visit the thread in the forum and click the camera icon: https://forums.adobe.com/message/7741194#7741194
To unsubscribe from this thread, please visit the message page at , click "Following" at the top right, & "Stop Following"
Start a new discussion in Installing Flash Player by email or at Adobe Community
For more information about maintaining your forum email notifications please go to https://forums.adobe.com/thread/1516624.
PLEASE DO NOT SEND ANYMORE MESSAGES ABOUT FLASH PLAYER TO ME.
THANKS,
DON
Begin forwarded message:
I had bounced (manually) from proxy to auto-detect proxy settings for this network—might have been in that state when the successful install occurred—had set it back to no proxy before receiving your request—both selections had resulted in a connection fail
I saw not the crest
Russ Lovick
<edit to remove personal information>
Adobe Employee ,
Hi kz94b5,
Thank you for the additional information.  I have forwarded the log file and this thread to the team that handles the online installer, which is returning the error.  They'll investigate further.
Maria
I am experiencing this same problem and have tried the steps listed below with no success. Is there any way to save flash player on a flash drive from another computer and download it to this affected computer?
Frustrated,
Jen
Adobe Employee ,
Hi kitykat1074,
The offline installers posted at the bottom of the Installation problems | Flash Player | Windows‌ page in the 'Still having problems' section.  This can be used on the same computer where the online installer is failing since it is the full installer whereas the online installer downloads and installs Flash Player silently in the background and it is this background downloading of the installer that is failing.
While a number of users are experiencing this behaviour, we have not been able to reproduce it and would appreciate it if you could provide us with the install log files for the online installer to help troubleshoot.  If you have a few minutes, please do the following:
  1. Create an empty text file named ADM.trace inside your %temp% directory.  The file extension itself is .trace, not .txt or anything else.
      • Vista and above: C:\Users\<YourUserID>\AppData\Local\Temp\
      • XP: C:\Documents and Settings\<YourUserID>\Local Settings\Temp\
    • To create the empty text file, navigate to the %temp% directory, right-click in an empty area and select New > Text Document
    • Rename the new file to ADM.trace
  2. Run the online installer again until it stops
  3. Locate the Adobe_ADM.log and Adobe_GDE.log files inside the Adobe_ADMLogs directory in the %temp% directory
  4. Upload both of the files in this directory using the instructions here How to share a document‌
  5. Post the link to the files in your reply.
Thank you in advance.
Maria
Adobe Employee ,
Hi kitykat1074,
Thank you.  I've forwarded the log files to the team that handles the online installer.
Maria
