RH X5 (RoboHTML)
Jan 09, 2008 Jan 09, 2008
Hi All,
I am new to this forum.
I have a problem where X5 closes with error when I double-click an HTML File (Topics) top left side of RoboHelp HTML. The error is "An unhandled win32 exception occurred in RoboHTML.exe[4004]." and Visual Studio askes me if I want to debug the problem. I click the "No" button and RHX5 closes.
I have installed the patch (X5.0.2) for X5. I also installed X5 on a different PC with the same results.
Has anyone seen this problem?
Thank you inadvance,
Sean
252
Jan 10, 2008 Jan 10, 2008
Hi:
Try the following to recreate the *.CPD and *.XPJ files.
1. Close RoboHelp HTML.
2. Delete the .CPD and .XPJ files located in your project folder.
(The Getting Started folder)
3. Right click the *.HHP file (in the same folder as the files listed above) then select Edit.
This should re-opoen the project in RoboHelp.
4. Save and then compile the project.
Jan 11, 2008 Jan 11, 2008
Hi Bdeeb,
Thanks for your suggestion. I have worked out that the RH is crashing because the HTML files have links in them that RH cannot handle.
I solved my problem by importing FrameMaker .MIF files into RH instead of HTML files. Much easier and much cleaner.
Thanks again,
Sean
RoboHelp Documentation
Download Adobe RoboHelp
