Locked
Connection error also((((
Jul 09, 2015 Jul 09, 2015
I can't install flash palyer it goes only to 4% and then says Connection error and terminates.
Please help!
Windows 7, 32 bit
Firefox 39
Flash - 18.0.0.203
578
New Here , Jul 10, 2015 Jul 10, 2015
Thanks a lot.
I used ofline installer first then twice tried online installer. Second time online installed worked and finally I had to enable Flash plugin in Firefox and it finally worked.
Thanks a lot!
Adobe Employee ,
Please Uninstall your current flash player using Uninstall Flash Player | Windows and install offline installer. Flash Player for Firefox - NPAPI
Adobe Employee ,
Hi joeld78345585‌,
Please try restarting your system and this time turn off your Anti-virus. If this doesn't work please find the offline installer at Installation problems | Flash Player | Windows Page (at the bottom).
Piyush
Thanks a lot.
Thanks a lot!
Adobe Employee ,
Hi joeld78345585,
We are aware of the connection error issue and are investigating it.  We'd appreciate it if you could provide the install logs.  If you have a few minutes, please do the following:
  1. Create an empty text file named ADM.trace inside your %temp% directory (usually C:\Users\<YourUserID>\AppData\Local\Temp\).  The file extension itself is .trace, not .txt or anything else.
    • To create the empty text file, navigate to the %temp% directory, right-click in an empty area and select New > Text Document
    • Rename the new file to ADM.trace
  2. Run the online installer again until it stops
  3. Locate the Adobe_ADM.log and Adobe_GDE.log files inside the Adobe_ADMLogs directory in the %temp% directory
  4. Upload both of the files in this directory using the instructions here How to share a document
  5. Post the link to the files in your reply.
Thank you in advance.
Maria
