Locked
Is there a Flash ActiveX registry cleaner?
Guest
May 18, 2012 May 18, 2012
Recently it has come to our attention that one of the version 10 Flash Player ActiveX releases caused registry problems that prevented successful upgrades even after the deployment has shown a successful installation via SCCM. The bad version caused a series of registry artifacts, and bad entries in Add/Remove Programs (as many as 8 bad entries from previous upgrades). This is now causing some complaints among users, and investigation has revealed an alarming number of computers with broken Flash Player ActiveX installations.
The error we see on these computers is "Error 2753. The File 'InstallAX.exe' is not marked for installation."
Removing the registry entries by product GUID works, however there seems to be sporadic GUIDs, and missing even one of them will fail to solve the problem. Research based on this error has shown very spotty resolutions.
Is there a known-good script or program out there to fix this problem?
Thank you!
30.6K
Adobe Employee ,
Does it help if you run themost recent stand alone uninstaller first?
Chris
Guest
May 21, 2012 May 21, 2012
Thanks for the response Chris.
We have tried using the uninstaller and it reports a successful uninstall but all of the old versions are listed in the registry and is still unable to install a Flash ActiveX.package.
Only after deleting all reg entries with the Flash ActiveX GUIDs in HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\ are we able to install a Flash ActixeX package.
I would like to avoid trying to use a search and destroy script by keyword in the registries on this many machines. Frankly I have never written anything that complex for the registry and would like to avoid it altogether.
If there is an existing script that is known to be safe for this function, I'd love to see it.
Adobe Employee ,
May 22, 2012 May 22, 2012
I'm pinging our installer team for their input.  I'll let you know what they say.
Adobe Employee ,
May 23, 2012 May 23, 2012
Ok, we've got a few more questions for you.  Can we get:
1. What are the exact registry paths which still exist in the registry after running the uninstaller?
2. The FlashInstall.log from the following locations on a system that exhibits this issue?
C:\Windows\System32\Macromed\Flash\
C:\Windows\SysWOW64\Macromed\Flash\
If you'd prefer sending me the files, please feel free to contact me directly at ccampbel@adobe.com
Chris
Guest
May 25, 2012 May 25, 2012
Requested info sent via email.
Adobe Employee ,
Thanks again for sending the information along to us.  Here's what I've heard back.
We're not familiar with any of the registry entries or GUIDs (they don’t appear to be product GUIDs), although it’s possible that they are somehow related to our older MSI installer.
The entries appear to be part of the Microsoft installation sub-system and are not directly managed by Adobe.
I have heard of corruption issues that can occur on Windows which impact MSI upgrades/uninstalls, but such issues are beyond our control. We recommend investigate a fix on Microsoft’s support site.
I'm curious if running the Windows installer Fix-It and doing an uninstall via that would help.  It might be worth a try.
Microsoft Install and Uninstall Fix It
Adobe Employee ,
Aug 23, 2012 Aug 23, 2012
We're in the process of investigating this error but need help from community members.  If you're encountering the "...is not marked for installation" issue and would be willing to generate debug logs for us, please see the instructions below:
Perform the following steps on an impacted system
1. Download the appropriate "Debugging Tools for Windows" MSI installer which is available from:
** For 32 Bit systems: http://msdl.microsoft.com/download/symbols/debuggers/dbg_x86_6.11.1.404.msi
** For 64 Bit systems: http://msdl.microsoft.com/download/symbols/debuggers/dbg_amd64_6.11.1.404.msi
Click on Run
Click on Next
Click on "I agree" for the EULA
Click on Next
Select the radio button for "Custom"
Click on Browse and change the default install path to C:\DEBUGGERS
Click on Next
Click on Install
Click on Finish
2. Download the appropriate TTTSetup MSI installer:
** For 32 Bit systems: https://sendnow.acrobat.com/?i=7gBp4PSAtP9lB8UrdqBr6Q
** For 64 Bit systems: https://sendnow.acrobat.com/?i=9SfayRdL7gGV50TeYOpkTg
3. Copy the appropriate TTTSetup MSI installer to c:\debuggers
Double click on the MSI installer to execute
Click on "Next"
Click on "I accept" for the EULA
Click on "Next"
Ensure the install location reads C:\Debuggers\ttt\
Click on "Next"
Click on "Install"
4. Launch task manager and ensure that there are no running instances of msiexec.exe. If there are, end the running instances. This will help us isolate the msiexec.exe process(es) that are associated with the Flash Player MSI.
5. Launch the Flash Player 11 MSI installer but do not click on the Install button just yet.
6. Locate the msiexec.exe process(es) that appear in task manager after launching the Flash Player MSI. Take note of the PID(s) for msiexec.exe (you will need it later)
- If you do not see a PID column in Task Manager, you can add it from the task manager View pulldown menu (View->Select Columns)
7. Create the following folder C:\iDNAtrace
8. Open a command prompt and navigate to C:\Debuggers\ttt (cd C:\Debuggers\ttt)
- If you have two running instances of msiexec.exe, you will need to perform steps 8 - 10 in two separate command prompts in order to capture all MSI activity (one for each PID).
- If you are on Windows 7, you will need to launch the command prompt with the "Run As Administrator" command. To do this, click on Start, type cmd in the search field, right click on cmd.exe.
9. Type "TTtracer.exe -Initialize" without the quotation marks and then Press Enter.
10. Type "TTtracer.exe –dumpfull –maxfile 1024 –ring –out c:\iDNAtrace –attach PID” without the quotation marks, Press Enter. <Replace "PID" with the process ID for msiexec.exe from step 5 above>
11. click on the Flash Player 11 MSI Install button. When the Flash Player 11 MSI displays the error message, click on "Exit App" on the iDNA window on the desktop. This will create the .out and .run trace files in the C:\iDNAtrace folder
Please send the .run and .out files to ccampbel@adobe.com for further analysis.
Nov 27, 2012 Nov 27, 2012
The Fixit seems to work, but isn't a very good option for my organization that has 300+ machines choaking on Flash right now. Since this thread went dark in August has there been any solutions to this problem that can be automated across our network?
Guest
It seems to be unsupported. The best I could do has been to locate all of the relevant Flash reg entries I could find and delete them from the registry. This has so far deleted the multiple bad entries from Add/Remove and allowed the update to install without the InstallAX error coming up. Example, if you only have 5 versions to address since they shipped the bug:
Windows Registry Editor Version 5.00
[-HKEY_CLASSES_ROOT\Installer\Features\087B87245BC6A734ABA6137C9FAF9B08]
[-HKEY_CLASSES_ROOT\Installer\Features\5100A42EF37C75B48BFDE58BD4E26958]
[-HKEY_CLASSES_ROOT\Installer\Features\70EB3840D062D4E418E57F730C7AE204]
[-HKEY_CLASSES_ROOT\Installer\Features\92D60C7EA61B88D49A715524F2BAE4D9]
[-HKEY_CLASSES_ROOT\Installer\Features\BB211F0D2097CA34FA05D411719C51E2]
[-HKEY_CLASSES_ROOT\Installer\Products\087B87245BC6A734ABA6137C9FAF9B08]
[-HKEY_CLASSES_ROOT\Installer\Products\5100A42EF37C75B48BFDE58BD4E26958]
[-HKEY_CLASSES_ROOT\Installer\Products\70EB3840D062D4E418E57F730C7AE204]
[-HKEY_CLASSES_ROOT\Installer\Products\92D60C7EA61B88D49A715524F2BAE4D9]
[-HKEY_CLASSES_ROOT\Installer\Products\BB211F0D2097CA34FA05D411719C51E2]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\087B87245BC6A734ABA6137C9FAF9B08]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\5100A42EF37C75B48BFDE58BD4E26958]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\70EB3840D062D4E418E57F730C7AE204]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\92D60C7EA61B88D49A715524F2BAE4D9]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Products\BB211F0D2097CA34FA05D411719C51E2]
It is unclear if this covers everything to 100% genuinely solve the problem. We really need Adobe to maintain ownership of registry and file hygiene for changes they make.
I hope that helps at all.
Adobe Employee ,
Nov 29, 2012 Nov 29, 2012
We're looking into making a script that will clean these but I'm attaching a complete list of product codes in case someone gets to it before we do.
Jan 24, 2014 Jan 24, 2014
Here's a quick one based on the above product codes. However, Any v11.4+ product codes need to be added.
:: Adobe Flash Player ActiveX and Plugin Uninstall Script
REM Adobe Flash Player ActiveX ProductCodes
REM Adobe Flash Player v. 7.0
MsiExec.exe /uninstall {cdf0cc64-4741-4e43-bf97-fef8fa1d6f1c} /quiet /norestart
REM Adobe Flash Player v. 7.0.73.0
MsiExec.exe /uninstall {1ae3b442-f6e5-49a0-bf8b-0e8d56d7d450} /quiet /norestart
REM Adobe Flash Player v. 8.0.0.442 and earlier
MsiExec.exe /uninstall {436EE5F2-71F0-4738-B8E7-93741EF4828F} /quiet /norestart
MsiExec.exe /uninstall {0B575FB2-30B1-48F2-80A3-977638C2D6BA} /quiet /norestart
REM Adobe Flash Player v. 8.0.0.443 -> 8.0.0.453
MsiExec.exe /uninstall {F180E599-CC04-4971-8140-3F71F95D7944} /quiet /norestart
MsiExec.exe /uninstall {9600BCE2-9DEF-4930-ABF7-FB68ED538BF7} /quiet /norestart
REM Adobe Flash Player v. 8.0.0.454 -> 8.0.9.0
MsiExec.exe /uninstall {0A28C610-EE06-4A33-BB56-A2155B524916} /quiet /norestart
MsiExec.exe /uninstall {0CB2ABF4-BB8D-4F87-9223-50F106B50D95} /quiet /norestart
REM Adobe Flash Player v. 8.0.10.0 -> 8.0.22.0
MsiExec.exe /uninstall {6815FCDD-401D-481E-BA88-31B4754C2B46} /quiet /norestart
MsiExec.exe /uninstall {885A63EA-382B-4DD4-A755-14809B8557D6} /quiet /norestart
REM Adobe Flash Player v. 8.0.24.0
MsiExec.exe /uninstall {5E8A1B08-0FBD-4543-9646-F2C2D0D05750} /quiet /norestart
MsiExec.exe /uninstall {CD5C7EB6-937A-4E39-B847-A8A50568EE9B} /quiet /norestart
REM Adobe Flash Player v. 8.0.33.0
MsiExec.exe /uninstall {E8590564-FD80-4864-B219-619BD4B3EB83} /quiet /norestart
MsiExec.exe /uninstall {E67FAA8D-58E0-433C-833C-6647CDB14AB0} /quiet /norestart
REM Adobe Flash Player v. 8.0.34.0
MsiExec.exe /uninstall {F7BE8C66-4DFF-4480-A9B6-410E6FE4D399} /quiet /norestart
MsiExec.exe /uninstall {0B991365-EB79-40B3-92AE-5E09B4008553} /quiet /norestart
REM Adobe Flash Player v. 8.0.35.0
MsiExec.exe /uninstall {B0D584DC-3B46-4F6C-B9C3-BDC61304D3CD} /quiet /norestart
MsiExec.exe /uninstall {2927FFE6-25C2-4C86-B93C-EDEEA97B7CB7} /quiet /norestart
REM Adobe Flash Player v. 8.0.36.0
MsiExec.exe /uninstall {6D7EE95D-ADFB-4454-B28B-FAC56F84F186} /quiet /norestart
MsiExec.exe /uninstall {8A90EC49-E132-4AA5-BF74-A18CC3C6DF6D} /quiet /norestart
REM Adobe Flash Player v. 8.0.39.0
MsiExec.exe /uninstall {00C10AC2-32C3-4281-B8EB-011E00B5AE20} /quiet /norestart
MsiExec.exe /uninstall {2BBA59AE-9246-4348-8BB8-54EA1182817B} /quiet /norestart
REM Adobe Flash Player v. 8.0.42.0
MsiExec.exe /uninstall {A3703922-84E3-4318-B0A1-04EFAD449A04} /quiet /norestart
MsiExec.exe /uninstall {8A7DC982-6A96-4C3C-BBE1-D5025CD85AF5} /quiet /norestart
REM Adobe Flash Player v. 9.0.16.0
MsiExec.exe /uninstall {BB65C393-C76E-4F06-9B0C-2124AA8AF97B} /quiet /norestart
MsiExec.exe /uninstall {116E6EEC-0CBA-460E-8DEB-55CFF8E28C7D} /quiet /norestart
REM Adobe Flash Player v. 9.0.28.0
MsiExec.exe /uninstall {685A56F8-75B6-44AD-B3DA-FB0A3266B47C} /quiet /norestart
MsiExec.exe /uninstall {D26FEB21-3495-401F-9046-0A39050A9324} /quiet /norestart
REM Adobe Flash Player v. 9.0.45.0
MsiExec.exe /uninstall {8186E1B9-DDC6-45B6-B9EB-C28947CBC4CF} /quiet /norestart
MsiExec.exe /uninstall {6EB45C70-7B6E-456C-8C23-58A8409C0E3D} /quiet /norestart
MsiExec.exe /uninstall {BC4F8E84-5E29-49EC-B4E7-E6F9CB50986C} /quiet /norestart
REM Adobe Flash Player v.  9.0.XX.0
MsiExec.exe /uninstall {786547F9-59BB-4FA3-B2D8-327FF1F14870} /quiet /norestart
MsiExec.exe /uninstall {3420E724-6DDB-49C2-BA39-165F543C147C} /quiet /norestart
MsiExec.exe /uninstall {8E9DB7EF-5DD3-499E-BA2A-A1F3153A4DF8} /quiet /norestart
MsiExec.exe /uninstall {0A621EC5-B98B-45C9-95FE-A7D0DA3150EA} /quiet /norestart
REM Adobe Flash Player v.  9.4.XX.0
MsiExec.exe /uninstall {58BAA8D0-404E-4585-9FD3-ED1BB72AC2EE} /quiet /norestart
MsiExec.exe /uninstall {483CFBDB-5870-41ED-82DC-992D1A2CBA87} /quiet /norestart
REM Adobe Flash Player v.  9.0.151.0
MsiExec.exe /uninstall {74B3FB8A-2A0F-4CEA-84FD-12C9B03EE377} /quiet /norestart
MsiExec.exe /uninstall {693E05C4-15CF-4EC4-8298-AFCC049F4B94} /quiet /norestart
MsiExec.exe /uninstall {6FEFB724-6655-492B-9D10-00F530FC39D3} /quiet /norestart
MsiExec.exe /uninstall {41FA4099-8AAA-495C-B1F0-E0447F9F4A93} /quiet /norestart
REM Adobe Flash Player v.  9.0.246
MsiExec.exe /uninstall {9BA8B441-9E83-4307-A582-03EC9A456C72} /quiet /norestart
MsiExec.exe /uninstall {03E99F0B-3A02-4821-BD44-70D4463F897B} /quiet /norestart
REM Adobe Flash Player v. 9r260
MsiExec.exe /uninstall {BB79ADDE-9369-44C4-84DB-221C853ABEDC} /quiet /norestart
MsiExec.exe /uninstall {B4D79216-306A-400B-858B-00C05F0B0E80} /quiet /norestart
REM Adobe Flash Player v.  9.0.262
MsiExec.exe /uninstall {C64CF7F5-92A0-4615-AA2D-A1237AD3F332} /quiet /norestart
MsiExec.exe /uninstall {211986FD-3BB6-4B0D-8AAF-C22A6DBC7E36} /quiet /norestart
REM Adobe Flash Player v.  9.0.277
MsiExec.exe /uninstall {4FB5B082-6906-4764-9486-332393B33C9F} /quiet /norestart
MsiExec.exe /uninstall {7EC95A10-14F2-496A-99FA-772454E44566} /quiet /norestart
REM Adobe Flash Player v.  9.0.280
MsiExec.exe /uninstall {2CB88388-9DFB-46f7-B7F1-862EB29A6FAB} /quiet /norestart
MsiExec.exe /uninstall {17EDE3E8-7AF0-4c54-B6E7-0CA4129E9C21} /quiet /norestart
REM Adobe Flash Player v.  10.0.2
MsiExec.exe /uninstall {3A6829EF-0791-4FDD-9382-C690DD0821B9} /quiet /norestart
REM Adobe Flash Player v.  10.0.12
MsiExec.exe /uninstall {2BD2FA21-B51D-4F01-94A7-AC16737B2163} /quiet /norestart
MsiExec.exe /uninstall {A19AA51E-C145-4323-947E-D0D71EC84E47} /quiet /norestart
REM Adobe Flash Player v.  10.0.22
MsiExec.exe /uninstall {922E8525-AC7E-4294-ACAA-43712D4423C0} /quiet /norestart
MsiExec.exe /uninstall {CECF7500-69B8-4EEE-9A5F-8D2FC2625760} /quiet /norestart
REM Adobe Flash Player v.  10.0.32
MsiExec.exe /uninstall {B7B3E9B3-FB14-4927-894B-E9124509AF5A} /quiet /norestart
MsiExec.exe /uninstall {AFCD87D7-46F9-4923-84F0-987F12D0C28C} /quiet /norestart
REM Adobe Flash Player v. 10.0.42
MsiExec.exe /uninstall {24762012-C6C8-4AAD-A02D-71A009FA1683} /quiet /norestart
MsiExec.exe /uninstall {D4B2F658-FCCC-4C50-952B-A8A5E5BC110F} /quiet /norestart
REM Adobe Flash Player v. 10.0.45
MsiExec.exe /uninstall {66E3BA00-6B3D-466B-96FA-6309A7F42BB0} /quiet /norestart
MsiExec.exe /uninstall {20B3FD5B-A987-406B-A5B5-CDE3CA1EF4E1} /quiet /norestart
REM Adobe Flash Player v.  10.1.52
MsiExec.exe /uninstall {6E9EF98E-259E-416D-B5F8-0ABDB99942CE} /quiet /norestart
MsiExec.exe /uninstall {EFB786FD-D916-416B-A23A-1EBEAF4A9DDC} /quiet /norestart
REM Adobe Flash Player v.  10.1.55
MsiExec.exe /uninstall {FFB768E4-E427-4553-BC36-A11F5E62A94D} /quiet /norestart
MsiExec.exe /uninstall {95A0B13E-F09A-425F-9D5F-E7C5EC470D06} /quiet /norestart
REM Adobe Flash Player v. 10.1.82
MsiExec.exe /uninstall {406A89D6-09E6-4550-B370-8D376DDB56BE} /quiet /norestart
MsiExec.exe /uninstall {03A3CDEE-94D7-49c1-B373-D342653A22E8} /quiet /norestart
REM Adobe Flash Player v. 10.1.85
MsiExec.exe /uninstall {95468B00-C081-4B27-AC96-0A2A31359E60} /quiet /norestart
MsiExec.exe /uninstall {C6C0E5B3-19B9-45D4-B76A-177F500A276C} /quiet /norestart
REM Adobe Flash Player v. 10.1.102
MsiExec.exe /uninstall {148D9D03-5D23-4D4F-B5D0-BA6030C45DCF} /quiet /norestart
MsiExec.exe /uninstall {65EAFCCB-4057-4184-9145-137DED9E0144} /quiet /norestart
REM Adobe Flash Player v. 10.2.152
MsiExec.exe /uninstall {E5D03B2E-B2D4-477F-A60D-8E1969D821FA} /quiet /norestart
MsiExec.exe /uninstall {87AE8A8F-6040-42B5-A7E5-644B1EA70163} /quiet /norestart
MsiExec.exe /uninstall {18BBF24A-6D04-4CA4-B6B4-1CF372162EEC} /quiet /norestart
MsiExec.exe /uninstall {37C80158-721A-440E-8102-8C5B71BFE2DE} /quiet /norestart
REM Adobe Flash Player v. 10.2.153
MsiExec.exe /uninstall {B001064C-D061-4BAE-9031-416A838D5536} /quiet /norestart
MsiExec.exe /uninstall {FFE07581-220F-47B7-8EDE-26059EF9FB26} /quiet /norestart
REM Adobe Flash Player v. 10.2.159
MsiExec.exe /uninstall {FA1D6742-0515-4A94-AD5D-F0484026E4A2} /quiet /norestart
MsiExec.exe /uninstall {9A80D7E7-4C48-484E-9C16-F4E300366F1D} /quiet /norestart
REM Adobe Flash Player v. 10.3.181.14
MsiExec.exe /uninstall {DCC90D9D-4F8D-4A06-9050-ADDB284FF9FA} /quiet /norestart
MsiExec.exe /uninstall {23885D98-F1AF-4579-81FB-C57CA71B7E89} /quiet /norestart
REM Adobe Flash Player v. 10.3.181.22
MsiExec.exe /uninstall {A6FD09C6-E363-4986-8ABD-2165B4485EEC} /quiet /norestart
MsiExec.exe /uninstall {397B615E-7442-4BEA-8098-61BBCF703C74} /quiet /norestart
REM Adobe Flash Player v. 10.3.181.23
MsiExec.exe /uninstall {88D881EF-0567-443A-9A84-E5AAEF29BB34} /quiet /norestart
MsiExec.exe /uninstall {04F9616D-BEB9-40DD-88EA-0D404F67C775} /quiet /norestart
REM Adobe Flash Player v. 10.3.181.26
MsiExec.exe /uninstall {0483BE07-260D-4E4D-815E-F737C0A72E40} /quiet /norestart
MsiExec.exe /uninstall {332FDA1D-0B1E-460C-9961-65515CADB9B7} /quiet /norestart
REM Adobe Flash Player v. 10.3.181.34
MsiExec.exe /uninstall {48DB5914-8772-472D-B8DF-E2092BE598F6} /quiet /norestart
MsiExec.exe /uninstall {EA5AFEE8-17F9-4DC6-AB10-A41C34A35893} /quiet /norestart
REM Adobe Flash Player v. 10.3.183.5
MsiExec.exe /uninstall {72D4DD4C-0749-4352-B63E-7A7C9286430E} /quiet /norestart
MsiExec.exe /uninstall {A3F073DB-01A6-4e24-A0F5-950EAB651355} /quiet /norestart
REM Adobe Flash Player v. 10.3.183.6+
MsiExec.exe /uninstall {DB093E0B-0934-4183-BA60-5C1ADC9F6424} /quiet /norestart
MsiExec.exe /uninstall {C0D8060A-8E3B-458c-9434-FBBE04F823D3} /quiet /norestart
REM Adobe Flash Player v. 10.3.230
MsiExec.exe /uninstall {E24A0015-C73F-4B57-B8DF-5EB84D2E9685} /quiet /norestart
MsiExec.exe /uninstall {39BCE53F-F8C8-4545-A5D8-F210E7608360} /quiet /norestart
REM Adobe Flash Player v. 10.3.183.11
MsiExec.exe /uninstall {54DAAD16-A57A-4524-9C4F-391500945D14} /quiet /norestart
MsiExec.exe /uninstall {A437E1A3-F0AA-4EA2-8E43-845DDC2221D1} /quiet /norestart
REM Adobe Flash Player v. 10.3.183.15
MsiExec.exe /uninstall {36B194F6-D57F-4E58-B99D-9A4565356A66} /quiet /norestart
MsiExec.exe /uninstall {E84F69A8-5357-4C1F-B8AA-63919FA0BDA6} /quiet /norestart
REM Adobe Flash Player v. 10.3.183.16
MsiExec.exe /uninstall {FEE2740C-D52A-4C76-8857-335E35AB7037} /quiet /norestart
MsiExec.exe /uninstall {1D424BAA-E25C-456C-B502-0B9C9F164BDE} /quiet /norestart
REM Adobe Flash Player v. 10.3.183.18
MsiExec.exe /uninstall {212719F5-89EE-4B3A-A8EB-121D931E5547} /quiet /norestart
MsiExec.exe /uninstall {AB36B93A-7B6A-4693-99DE-95143819EE78} /quiet /norestart
REM Adobe Flash Player v. 10.3.183.19
MsiExec.exe /uninstall {2B2D7C9F-F652-4C9C-86AD-7298D2989D88} /quiet /norestart
MsiExec.exe /uninstall {DA69776C-A93F-4077-8874-25DF521EAA8A} /quiet /norestart
REM Adobe Flash Player v. 10.3.183.20
MsiExec.exe /uninstall {5C017C03-0DCF-47DD-8113-9CDE442C30E7} /quiet /norestart
MsiExec.exe /uninstall {C9BDE2F9-88BE-429B-B63B-5D40BA2FCE7F} /quiet /norestart
REM Adobe Flash Player v. 10.3.183.23
MsiExec.exe /uninstall {35685EF6-CB29-4FDE-8950-F570ED2BACB7} /quiet /norestart
MsiExec.exe /uninstall {654BA71A-B93E-4085-ABD7-83BA7DCA6C23} /quiet /norestart
REM Adobe Flash Player v. 10.3.183.25
MsiExec.exe /uninstall {CBCA1B4E-1DB3-4BBF-BD05-CF3A3F2CC32B} /quiet /norestart
MsiExec.exe /uninstall {09343F1F-926F-4DFD-8784-079E67D783DB} /quiet /norestart
REM Adobe Flash Player v. 10.3.183.x
MsiExec.exe /uninstall {1BB7D2BB-D4EB-4680-A707-FC3D526E90A1} /quiet /norestart
MsiExec.exe /uninstall {66C8B9D7-25FF-4BF9-A515-096E8D3B73EF} /quiet /norestart
REM Adobe Flash Player v. 11.0.1
MsiExec.exe /uninstall {23D79730-EC1A-435E-83F8-AAEBFE5237B0} /quiet /norestart
MsiExec.exe /uninstall {726D93B8-C973-4C5B-881B-96FBDE459D39} /quiet /norestart
MsiExec.exe /uninstall {A10EE46B-C2E8-4FAB-A8F8-3E80D0662BA9} /quiet /norestart
MsiExec.exe /uninstall {6C119C52-528E-4115-A05D-E78893FB01F6} /quiet /norestart
REM Adobe Flash Player v. 11.1.102
MsiExec.exe /uninstall {4278B780-6CB5-437A-BA6A-31C7F9FAB980} /quiet /norestart
MsiExec.exe /uninstall {DBC42D80-FE3F-4F45-91EA-972F0EDC8603} /quiet /norestart
MsiExec.exe /uninstall {421976B6-DEC6-4CA5-941F-F0663B3A2B74} /quiet /norestart
MsiExec.exe /uninstall {C2840D4B-5DD8-4813-A9D8-C2B72E821226} /quiet /norestart
REM Adobe Flash Player v. 11.1.102.62
MsiExec.exe /uninstall {D0F112BB-7902-43AC-AF50-4D1117C9152E} /quiet /norestart
MsiExec.exe /uninstall {B88C181E-D594-4A3C-9767-07E4794234D6} /quiet /norestart
MsiExec.exe /uninstall {62DD0E85-7A25-47A4-8F0F-95D749F9F102} /quiet /norestart
MsiExec.exe /uninstall {7DBA4E0E-C43E-4BD8-859E-DA4E8284473E} /quiet /norestart
REM Adobe Flash Player v. 11.1.102.63
MsiExec.exe /uninstall {8D7DDFA2-3A50-49A4-99C5-6D8BE66FE0B9} /quiet /norestart
MsiExec.exe /uninstall {3D093B2E-1E39-4097-A0EF-C70351A16CA6} /quiet /norestart
MsiExec.exe /uninstall {E7C06D29-B16A-4D88-A917-55422FAB4E9D} /quiet /norestart
MsiExec.exe /uninstall {82833D13-CE67-4DD9-A270-30265F12DCB7} /quiet /norestart
REM Adobe Flash Player v. 11.1.102.64
MsiExec.exe /uninstall {90790D5D-80D8-4C7E-8BDC-23DBB8C6AEC7} /quiet /norestart
MsiExec.exe /uninstall {CF722882-1ED7-4FB9-B98A-589544A15F40} /quiet /norestart
MsiExec.exe /uninstall {D3F3D07F-4B4F-440B-9DC9-355848A8103C} /quiet /norestart
MsiExec.exe /uninstall {14190A51-2712-42C1-B7DB-011ABEAF33E2} /quiet /norestart
REM Adobe Flash Player v. 11.2.202.228
MsiExec.exe /uninstall {5C804EBB-475F-4555-A225-1D6573F158BD} /quiet /norestart
MsiExec.exe /uninstall {E3C99F7A-60C3-40C4-BC9D-FB6B0C2F2671} /quiet /norestart
MsiExec.exe /uninstall {8DB09D25-8E79-4F23-854D-02B95062A5B2} /quiet /norestart
MsiExec.exe /uninstall {94B87B26-B746-4AEA-B301-4AB281AF3B7A} /quiet /norestart
REM Adobe Flash Player v. 11.2.202.233
MsiExec.exe /uninstall {9E25236A-E313-4853-9C8C-DB7015E9F9C4} /quiet /norestart
MsiExec.exe /uninstall {0EF12658-CB6B-4A73-923D-2CABE04976A6} /quiet /norestart
MsiExec.exe /uninstall {6B393C32-A8CE-4663-9D5B-EA75C8D1233C} /quiet /norestart
MsiExec.exe /uninstall {853E9330-9717-4504-BDA2-BB8743D458DD} /quiet /norestart
REM Adobe Flash Player v. 11.2.202.x
MsiExec.exe /uninstall {F40AC5E5-55AB-469A-BA8B-839CE0146380} /quiet /norestart
MsiExec.exe /uninstall {43E79717-8760-480E-8408-98D090DA10A7} /quiet /norestart
MsiExec.exe /uninstall {A13AB67F-697F-47DC-AA7B-F70B8B7ACDB8} /quiet /norestart
MsiExec.exe /uninstall {628185FB-FA33-49C3-B7AC-A31F30EDDB6E} /quiet /norestart
REM Adobe Flash Player v. 11.3.300.257
MsiExec.exe /uninstall {DC48E09D-4E5F-4039-B93A-FCED36EFBE55} /quiet /norestart
MsiExec.exe /uninstall {F856A189-24F9-4443-A40C-58CC70A1B336} /quiet /norestart
REM Adobe Flash Player v. 11.3.300.265
MsiExec.exe /uninstall {BEE621F9-F94D-493C-BC45-D1B315DC8839} /quiet /norestart
MsiExec.exe /uninstall {1F25D9AF-12DF-4A9D-B190-C6ED384520AF} /quiet /norestart
REM Adobe Flash Player v. 11.3.300.268
MsiExec.exe /uninstall {98616875-CF30-4BE5-AAED-36EF4AC6EE27} /quiet /norestart
MsiExec.exe /uninstall {8E55A5FE-A5D2-4791-A725-A8BA275BD3C2} /quiet /norestart
REM Adobe Flash Player v. 11.3.300.270
MsiExec.exe /uninstall {A02F7026-D635-465C-80D8-FB47AF185934} /quiet /norestart
MsiExec.exe /uninstall {0A665F5E-78A3-4BDB-B702-61B56815F91C} /quiet /norestart
REM Adobe Flash Player v. 11.3.300.271
MsiExec.exe /uninstall {25F2AB39-E3DD-4cd7-8697-E98CF27BA1F1} /quiet /norestart
MsiExec.exe /uninstall {98CBB17F-A22C-43e3-8521-99A3F413C882} /quiet /norestart
REM Adobe Flash Player v. 11.3.300.272
MsiExec.exe /uninstall {CA6C70E3-1878-47c3-97BA-8DB0E2221511} /quiet /norestart
MsiExec.exe /uninstall {ABE4FCDC-7D0B-40ea-ACD4-122BABC6E78A} /quiet /norestart
REM Adobe Flash Player v. 11.4.402.265
MsiExec.exe /uninstall {3F67CDB0-824E-435E-BE14-D7BCA8256E3E} /quiet /norestart
MsiExec.exe /uninstall {8A48D60D-7D7F-4C4D-AC92-AC3150BF75FE} /quiet /norestart
REM Adobe Flash Player v. 11.4.402.278
MsiExec.exe /uninstall {6F702A65-629F-4E5A-B686-1A4826C83AB4} /quiet /norestart
MsiExec.exe /uninstall {D488AE94-47DF-443E-8CE7-1A9A919B368A} /quiet /norestart
REM Adobe Flash Player v. 11.4.402.287
MsiExec.exe /uninstall {D01750A5-49E5-4BF4-92CC-F72F5F20DBEC} /quiet /norestart
MsiExec.exe /uninstall {A5FC3413-878E-4A9E-903A-7E32079C70F3} /quiet /norestart
REM Flash Player Plug-in ProductCodes
REM Adobe Flash Player v.8.0.0.442 and earlier
MsiExec.exe /uninstall {F6E23569-A22A-4924-93A4-3F215BEF63D2} /quiet /norestart
MsiExec.exe /uninstall {AF6106EF-F27F-4729-922B-FDD56869C9D0} /quiet /norestart
REM Adobe Flash Player v.8.0.0.443 -> 8.0.0.453
MsiExec.exe /uninstall {B9E91AEF-2A3C-4B48-BF18-456BE6EDF863} /quiet /norestart
MsiExec.exe /uninstall {5F2B85E0-66F2-4E61-BA50-12784EFAE696} /quiet /norestart
REM Adobe Flash Player v.8.0.0.454 -> 8.0.9.0
MsiExec.exe /uninstall {555D21DF-105A-48A7-AFFE-F5B4495F7F1D} /quiet /norestart
MsiExec.exe /uninstall {27DCBDC9-00D0-4A57-BDFD-E618820495CB} /quiet /norestart
REM Adobe Flash Player v.8.0.10.0 -> 8.0.22.0
MsiExec.exe /uninstall {23AEBB83-CB47-4739-8A0C-92CC1E32AA2F} /quiet /norestart
MsiExec.exe /uninstall {91057632-CA70-413C-B628-2D3CDBBB906B} /quiet /norestart
REM Adobe Flash Player v.8.0.24.0
MsiExec.exe /uninstall {E3D278BD-FC97-4F87-BB1F-689AE0CB9122} /quiet /norestart
MsiExec.exe /uninstall {13816489-2692-49A2-9615-0F2830E1740D} /quiet /norestart
REM Adobe Flash Player v.8.0.33.0
MsiExec.exe /uninstall {465B0B1A-06E1-4C99-BB0A-ED23262DF156} /quiet /norestart
MsiExec.exe /uninstall {C0C08739-EA05-443C-BE3F-2B4E46D6A74E} /quiet /norestart
REM Adobe Flash Player v.8.0.34.0
MsiExec.exe /uninstall {7DCC858F-082F-4E01-9DD4-CF3645640F41} /quiet /norestart
MsiExec.exe /uninstall {8672D374-FC95-45E0-B85C-BEB639C14F1F} /quiet /norestart
REM Adobe Flash Player v.8.0.35.0
MsiExec.exe /uninstall {EFEC4901-E9F0-4FB0-87F2-90E3058DA015} /quiet /norestart
MsiExec.exe /uninstall {0402AE0D-C6B5-4CBD-9A84-A0C32785D407} /quiet /norestart
REM Adobe Flash Player v.8.0.36.0
MsiExec.exe /uninstall {D60837D1-6881-4414-AD27-8A2042D043B3} /quiet /norestart
MsiExec.exe /uninstall {C1CC20FA-52A7-4F67-BCCC-5E55E9A61C6A} /quiet /norestart
REM Adobe Flash Player v.8.0.39.0
MsiExec.exe /uninstall {63C0B69C-6630-44F2-B3A4-1F50DDEF6ADD} /quiet /norestart
MsiExec.exe /uninstall {E1475528-CAC4-4919-81FD-EDC556097048} /quiet /norestart
REM Adobe Flash Player v.8.0.42.0
MsiExec.exe /uninstall {48D9A460-9FA3-4E16-9533-2DF1C1F5129F} /quiet /norestart
MsiExec.exe /uninstall {E686D1C1-78B5-4E1A-8269-A023B43C2D76} /quiet /norestart
REM Adobe Flash Player v.9.0.16.0
MsiExec.exe /uninstall {1E37DD02-3E30-49B6-9FF2-F4A3DFF95717} /quiet /norestart
MsiExec.exe /uninstall {626CA84A-FFAE-4978-A600-B0196F0F817D} /quiet /norestart
REM Adobe Flash Player v.9.0.28.0
MsiExec.exe /uninstall {0234731F-1444-4215-BBCE-968CDDB4BCA4} /quiet /norestart
MsiExec.exe /uninstall {008F31A9-4B8E-4411-AA19-2CB3C8DD7507} /quiet /norestart
MsiExec.exe /uninstall {391474F7-0DF1-445C-8888-34EEA7480927} /quiet /norestart
REM Adobe Flash Player v.9.0.45.0
MsiExec.exe /uninstall {B91D3B4D-001F-4ABF-B8A5-B5A926DB63AD} /quiet /norestart
MsiExec.exe /uninstall {56E0400B-3C4E-4600-A4D7-425EAE09E079} /quiet /norestart
MsiExec.exe /uninstall {88D422DB-E9C7-4E16-9D80-2999F4FD6AD9} /quiet /norestart
MsiExec.exe /uninstall {04B848BE-8B67-4B44-929D-BC14D9B4FFF4} /quiet /norestart
MsiExec.exe /uninstall {3EA70573-43D9-4F0F-B197-6015B404EFB5} /quiet /norestart
MsiExec.exe /uninstall {9802AB7D-9BB2-4FC9-A9B6-681696F1E2DA} /quiet /norestart
MsiExec.exe /uninstall {5746C6E3-DC6E-4762-9445-F89C50B5E1D2} /quiet /norestart
MsiExec.exe /uninstall {61E8B062-51F9-4BBB-B1FC-E2A4A40944F5} /quiet /norestart
MsiExec.exe /uninstall {ECF27176-4815-4F75-98DC-3E5568166C97} /quiet /norestart
MsiExec.exe /uninstall {84490045-A165-4E48-9513-F9624D2CEBEE} /quiet /norestart
MsiExec.exe /uninstall {A03AF447-5F61-43EC-880A-A65ED11C9720} /quiet /norestart
MsiExec.exe /uninstall {15769488-ECC7-482D-B222-96281A8C36C7} /quiet /norestart
MsiExec.exe /uninstall {3F38C13F-97A6-44B5-AB0F-5013801454B7} /quiet /norestart
REM Adobe Flash Player v. 9.0.246.0
MsiExec.exe /uninstall {EAC34337-5F49-41FF-86C6-A370DAB69CB2} /quiet /norestart
MsiExec.exe /uninstall {AF214EE7-1AF3-498F-918C-581F97B1EE79} /quiet /norestart
MsiExec.exe /uninstall {F201F161-D43B-471A-A9E5-C432E1BA196B} /quiet /norestart
MsiExec.exe /uninstall {E374CFF5-A81F-4C23-A278-8E19C913C23C} /quiet /norestart
REM Adobe Flash Player v. 9r262
MsiExec.exe /uninstall {35657C68-91B5-42EC-99E6-0BA43106AF8B} /quiet /norestart
MsiExec.exe /uninstall {9D2AA1D9-65D0-49E9-85A3-B73C9224F1F0} /quiet /norestart
MsiExec.exe /uninstall {E09CDDD4-060D-4BF4-AB36-C13AD9AD63A3} /quiet /norestart
MsiExec.exe /uninstall {AAA3B45B-8FD5-4DD1-86C6-C861EF0BA31C} /quiet /norestart
MsiExec.exe /uninstall {22A5BE4F-4A7C-4037-8E30-EAF0E6CB546C} /quiet /norestart
MsiExec.exe /uninstall {15F93695-7814-43b7-B078-35855A39B63C} /quiet /norestart
REM Adobe Flash Player v. 10.0.1.218
MsiExec.exe /uninstall {3F490EB6-7C6C-4208-93FF-6AC925FA64C8} /quiet /norestart
MsiExec.exe /uninstall {03DEEAD2-F3B7-45BF-9006-A25D015F00D2} /quiet /norestart
MsiExec.exe /uninstall {ECA1A3B6-898F-4DCE-9F04-714CF3BA126B} /quiet /norestart
MsiExec.exe /uninstall {5D8E406B-D572-4773-BE82-7B4B33F5167F} /quiet /norestart
MsiExec.exe /uninstall {64001313-1B41-4457-B884-049984772E6F} /quiet /norestart
MsiExec.exe /uninstall {4B475346-CE49-402C-991E-3DAF7074E337} /quiet /norestart
MsiExec.exe /uninstall {0DFB3DE8-65B9-44FF-AA0A-3BECC5A2BFD1} /quiet /norestart
MsiExec.exe /uninstall {D6627D6D-E144-49AF-8783-BBEA98B9DC20} /quiet /norestart
MsiExec.exe /uninstall {D09E3C22-6573-4723-9962-B3B2ED761754} /quiet /norestart
MsiExec.exe /uninstall {B67CE1B7-EDD4-4C70-AB8E-6008D029DD03} /quiet /norestart
MsiExec.exe /uninstall {AF36CE1D-FD2C-4BA0-93FA-1196785DD610} /quiet /norestart
MsiExec.exe /uninstall {903BE60B-0336-40A0-9024-6D980D1452C2} /quiet /norestart
MsiExec.exe /uninstall {BC41C09D-FAA9-4346-9FE6-1E0017BC551A} /quiet /norestart
MsiExec.exe /uninstall {359FC4B0-29ED-4CA8-AD66-CF436931F492} /quiet /norestart
MsiExec.exe /uninstall {1C5EC8F6-5C5F-421F-85BE-919B5D0CAD4C} /quiet /norestart
MsiExec.exe /uninstall {14CAE90A-7395-4DF6-93AD-14AF6E52922B} /quiet /norestart
MsiExec.exe /uninstall {012CE096-06BA-4f46-8E89-0B4F900E7479} /quiet /norestart
MsiExec.exe /uninstall {A7FCCC54-F5FB-4610-A47D-BB0B236EC0A0} /quiet /norestart
MsiExec.exe /uninstall {343DB62F-891F-45EC-BED3-E2F56CEB1B7C} /quiet /norestart
MsiExec.exe /uninstall {4ABE9922-AE51-4B1B-9058-9CD3B61CA28B} /quiet /norestart
MsiExec.exe /uninstall {35F7D0BF-08AB-42E3-A403-AF9772AC216A} /quiet /norestart
MsiExec.exe /uninstall {D70FE37C-CDB9-4C87-A60C-9619536A1817} /quiet /norestart
MsiExec.exe /uninstall {E6725026-A650-449C-897B-D6B7A5EEA058} /quiet /norestart
MsiExec.exe /uninstall {EF131455-5740-4A8D-8B58-30895FEA1C41} /quiet /norestart
MsiExec.exe /uninstall {FC619975-A025-4B54-873C-FDF000B90261} /quiet /norestart
MsiExec.exe /uninstall {FAFBF4A2-0CE2-4A80-908D-9C1B007CA821} /quiet /norestart
MsiExec.exe /uninstall {9C542173-96F0-435D-A95C-468CAAC75EA0} /quiet /norestart
MsiExec.exe /uninstall {ABD26AA9-1114-4470-8971-E4AF80177DF1} /quiet /norestart
MsiExec.exe /uninstall {F473C85C-1FED-4D0A-8155-E97AC7E43C9D} /quiet /norestart
MsiExec.exe /uninstall {58083D97-7080-4018-8205-755D57BDCCEE} /quiet /norestart
MsiExec.exe /uninstall {B7BDAF22-9647-4846-8EA9-6E0A5B785651} /quiet /norestart
MsiExec.exe /uninstall {EE13B869-5ED6-4304-BDAB-97FCD19196BD} /quiet /norestart
MsiExec.exe /uninstall {4ED0DB47-769D-4B71-8724-E7A5BFEA1D51} /quiet /norestart
MsiExec.exe /uninstall {2B30EEBE-80A5-4EC2-80BF-73B68D497A4A} /quiet /norestart
MsiExec.exe /uninstall {53F29A32-7D03-4635-A8B3-839D921F6F96} /quiet /norestart
MsiExec.exe /uninstall {E6BF9E13-E356-456B-9FA7-51DB3E0FB4FF} /quiet /norestart
MsiExec.exe /uninstall {F9D68131-7490-4448-AC45-7BBFB3392F8F} /quiet /norestart
MsiExec.exe /uninstall {1397D1B4-6341-4D7F-AE9A-4AD5D8569865} /quiet /norestart
MsiExec.exe /uninstall {8B234375-EFB1-4024-8B53-EA7C745A6687} /quiet /norestart
MsiExec.exe /uninstall {C0494ABC-1F71-4a95-A31F-C9DE5510253B} /quiet /norestart
MsiExec.exe /uninstall {8FC6B896-6F86-4957-AC1A-077A755C4F08} /quiet /norestart
MsiExec.exe /uninstall {D6CF54D5-35D1-4c14-BF01-682012C4A303} /quiet /norestart
MsiExec.exe /uninstall {10C35266-87DE-471F-B3C9-9AD0CA0315DE} /quiet /norestart
MsiExec.exe /uninstall {F9295F4F-A64E-4560-8934-B0B214A79C1B} /quiet /norestart
MsiExec.exe /uninstall {F9D28ACF-D568-4D4C-9601-2ECEE27479A3} /quiet /norestart
MsiExec.exe /uninstall {9777D3B0-B104-4337-937F-BD670CA08D3B} /quiet /norestart
MsiExec.exe /uninstall {FDBF4291-7DDB-4C5C-B128-332A46CF8FFA} /quiet /norestart
MsiExec.exe /uninstall {27B80FE1-E9ED-49D9-8EF4-C58635203EBE} /quiet /norestart
MsiExec.exe /uninstall {1B771BDD-6B21-4C61-A458-226910A9C01B} /quiet /norestart
MsiExec.exe /uninstall {34C45997-475F-4D02-9F2C-9FFE3880337D} /quiet /norestart
MsiExec.exe /uninstall {55D873F4-67F0-4BA8-B735-06A5B99AFFE1} /quiet /norestart
MsiExec.exe /uninstall {91522620-E5A9-4B76-856F-5159D18E2737} /quiet /norestart
MsiExec.exe /uninstall {1F282E23-66C7-46D3-B23C-70A53342DD4E} /quiet /norestart
MsiExec.exe /uninstall {ADF9B3BD-14A4-4A34-8382-9FD5757E950F} /quiet /norestart
MsiExec.exe /uninstall {99BEFA2A-9084-437E-BE21-40F850C1CF47} /quiet /norestart
MsiExec.exe /uninstall {4C66C92E-56EA-4769-ABD0-FA838A594D53} /quiet /norestart
MsiExec.exe /uninstall {F78DFF86-B53D-4D6D-AB2B-573C0A7AA856} /quiet /norestart
MsiExec.exe /uninstall {59CCE106-1DF5-4021-9700-FDFA2878ED41} /quiet /norestart
MsiExec.exe /uninstall {AB47EA27-9FE1-4775-BEFC-4AAEEE2CB53E} /quiet /norestart
MsiExec.exe /uninstall {781B0936-390B-4E1B-BC04-6B17D64E6451} /quiet /norestart
MsiExec.exe /uninstall {95758145-3B5B-4874-B062-597C8E450EA7} /quiet /norestart
MsiExec.exe /uninstall {73C4CC71-510B-44AD-AAA3-3C373963AED4} /quiet /norestart
MsiExec.exe /uninstall {66EE3C89-25FD-4D8F-BC01-B94B25B9D03F} /quiet /norestart
MsiExec.exe /uninstall {C4E5725D-2758-4FA3-A595-159BBCC5D42C} /quiet /norestart
MsiExec.exe /uninstall {CA6DA0CF-2852-4407-ADE2-CA6281C8CE9D} /quiet /norestart
MsiExec.exe /uninstall {C77FD7CE-3E63-4DA2-9EE6-D28F47846DCE} /quiet /norestart
MsiExec.exe /uninstall {4ABA8D5B-55F4-4254-905B-ACF8AAFF84EE} /quiet /norestart
MsiExec.exe /uninstall {605DFBA7-A719-4F7E-A035-84B2CAA7DD4E} /quiet /norestart
MsiExec.exe /uninstall {063C0043-E954-4850-9AA7-F9BC4E920D38} /quiet /norestart
MsiExec.exe /uninstall {99798FE8-28DA-421D-9A45-6CFB0C459E5C} /quiet /norestart
MsiExec.exe /uninstall {35E1B1BF-D8E5-4B7F-9FD6-87D2E5694015} /quiet /norestart
MsiExec.exe /uninstall {E7051553-A13A-437A-9133-11F8E88F21A8} /quiet /norestart
MsiExec.exe /uninstall {9243F09B-3319-4A55-8181-9BCEC7391079} /quiet /norestart
MsiExec.exe /uninstall {E3DB71DB-C4C8-479A-A8C9-C73EF2499B24} /quiet /norestart
MsiExec.exe /uninstall {F7090575-8BDC-4A14-8D00-C0FB2BC914BD} /quiet /norestart
MsiExec.exe /uninstall {2239879A-3B8C-4CB8-A98E-5881193A7128} /quiet /norestart
MsiExec.exe /uninstall {0F2C43BC-2B06-4684-BC2E-C922056DE90C} /quiet /norestart
MsiExec.exe /uninstall {2187F9AC-D040-4B1C-B636-40A5A8E63C54} /quiet /norestart
MsiExec.exe /uninstall {E3FB4C86-2BF1-4327-B7D4-60F9A2F0A32F} /quiet /norestart
MsiExec.exe /uninstall {9EBB117C-1326-400E-95A1-EF538815334B} /quiet /norestart
MsiExec.exe /uninstall {1E75E46A-D67F-44BC-9344-8EAA358E9FB7} /quiet /norestart
MsiExec.exe /uninstall {94B0D4F0-F2AC-4FE2-B384-C81507AAAE7C} /quiet /norestart
MsiExec.exe /uninstall {F1F9D254-FBB7-4634-9481-BEF1312255FE} /quiet /norestart
MsiExec.exe /uninstall {B87883B7-F397-400F-B700-6934464D2316} /quiet /norestart
MsiExec.exe /uninstall {12F0097F-68B4-40AB-A968-318D369027EC} /quiet /norestart
MsiExec.exe /uninstall {9D2F6D68-14FA-44BF-9137-3AE0EE11E609} /quiet /norestart
MsiExec.exe /uninstall {1E4B6678-A507-4B6A-B6C7-FEE55FC0C14C} /quiet /norestart
MsiExec.exe /uninstall {9C61F315-7DDF-4481-884C-3AEE83738806} /quiet /norestart
MsiExec.exe /uninstall {B2883418-71EB-4F63-97AB-222C67E99358} /quiet /norestart
MsiExec.exe /uninstall {EA5FD27F-D7A5-421A-8424-7DC27F62F7C9} /quiet /norestart
MsiExec.exe /uninstall {5D8B877C-945B-49F5-AA48-776C81C11B56} /quiet /norestart
MsiExec.exe /uninstall {6B9F3B5E-D16C-49A6-9DD4-ACFD69A561BC} /quiet /norestart
MsiExec.exe /uninstall {E648FE50-7E0B-45E2-92ED-AB1FD4493293} /quiet /norestart
MsiExec.exe /uninstall {7AD8EB38-C7C0-453A-BEC6-D7149EA62EC3} /quiet /norestart
MsiExec.exe /uninstall {3D3085B0-BC4D-4559-B0AE-F5C879DEFFC4} /quiet /norestart
MsiExec.exe /uninstall {CF753404-1C40-437F-859E-7EA8BEDABC64} /quiet /norestart
REM Adobe Flash Player v. 11.3.300.262
MsiExec.exe /uninstall {309970D0-D0E2-49AB-B9A2-80F48E22947A} /quiet /norestart
MsiExec.exe /uninstall {D13D4F0A-6D90-415B-88A9-3E31EE3A5410} /quiet /norestart
MsiExec.exe /uninstall {417EF49A-B315-449F-9652-85C8CB988042} /quiet /norestart
MsiExec.exe /uninstall {2BEF1A84-6975-4339-9E06-A70A6EE0CFE8} /quiet /norestart
MsiExec.exe /uninstall {9BFB1FAB-8FC4-4FAA-9B2D-2B121834B659} /quiet /norestart
MsiExec.exe /uninstall {DEA37712-5F54-4EF8-AD50-35D1181F79BF} /quiet /norestart
MsiExec.exe /uninstall {4C85A58E-48BA-4252-90C5-C9CA5E0C83D7} /quiet /norestart
MsiExec.exe /uninstall {244137C6-0414-48C9-BEFC-EAABDDB910AA} /quiet /norestart
MsiExec.exe /uninstall {05AADFE6-43D6-4c7c-9433-5F6EF02BF44F} /quiet /norestart
MsiExec.exe /uninstall {A26798D5-245C-4071-9681-9CE85731A115} /quiet /norestart
MsiExec.exe /uninstall {395CFBE7-19F1-4494-8ECF-6392D459CE0A} /quiet /norestart
MsiExec.exe /uninstall {84D0FEC8-D375-448e-9CA6-7A00BD1C4519} /quiet /norestart
REM Adobe Flash Player v. 11.4.402.256
MsiExec.exe /uninstall {97E0DCFB-4CBE-4DA6-955E-B8E4DE37E466} /quiet /norestart
MsiExec.exe /uninstall {9B560327-156A-46D3-9055-35B3DC5E656F} /quiet /norestart
MsiExec.exe /uninstall {8C27E4F1-9CE6-4C32-ADBB-D51CD226649E} /quiet /norestart
MsiExec.exe /uninstall {84B1F33D-5AA3-4669-89BC-CACE194EE877} /quiet /norestart
MsiExec.exe /uninstall {709D081A-4E86-43F5-9D67-6EAF47EE585E} /quiet /norestart
MsiExec.exe /uninstall {5E076E3C-9C1C-49C7-B53C-6ECE986F073A} /quiet /norestart
Jul 10, 2015 Jul 10, 2015
going to bring this back from the dead...
we have 1000+ PC's "win7 64" in the company, when we deploy the new flash in sccm 2012, we are getting from a 30 to 50% fail rate on installs
whats going on is it "thinks" or sometimes has MULTIPLE versions of older flash installed that WONT uninstall, because its looking for a MSI patch that no longer exists.
for us, its versions 16, 17, and now 18
i have built a Flash NUKE BAT file that 1st runs the uninstall_flash_player.exe, then
taskkill /f /im firefox.exe /t
taskkill /f /im palemoon.exe /t
taskkill /f /im iexplore.exe /t
taskkill /f /im iexplorer.exe /t
taskkill /f /im skype.exe /t
taskkill /f /im msiexec.exe /t
then
net stop AdobeARMservice
sc delete AdobeARMservice
net stop armsvc
sc delete armsvc
net stop AdobeFlashPlayerUpdateSvc
sc delete AdobeFlashPlayerUpdateSvc
then
RMDIR /S /Q "%appdata%\Adobe\Flash Player"
RMDIR /S /Q "%appdata%\Macromedia\Flash Player"
del /F /Q "%SystemDrive%\Windows\tasks\Adobe Flash Player Updater.job"
then
wmic product where "name like 'Adobe Flash Player%%'" call uninstall /nointeractive
and even after all of that, there is still registry info left that it thinks it has a old version installed that it cant..
the last keys i found in here
when i do i search in REG for "Adobe Flash Player" ill find the stray keys and if i deleted them, the installer will work fine.
the last key it found was this..
[HKEY_CLASSES_ROOT\Installer\Products\4769600BC08DBC8458D288DA63AE0B5A]
"Clients"=hex(7):3a,00,00,00,00,00
"ProductName"="Adobe Flash Player 18 NPAPI"
"PackageCode"="6A58C9D43DBAC79468217A9F04BFE636"
"Language"=dword:00000409
"Version"=dword:12000000
"Assignment"=dword:00000001
"AdvertiseFlags"=dword:00000180
"ProductIcon"="C:\\Windows\\Installer\\{B0069674-D80C-48CB-852D-88AD36EAB0A5}\\ARPPRODUCTICON.exe"
"InstanceType"=dword:00000000
"AuthorizedLUAApp"=dword:00000000
"DeploymentFlags"=dword:00000001
[HKEY_CLASSES_ROOT\Installer\Products\4769600BC08DBC8458D288DA63AE0B5A\SourceList]
"PackageName"="install_flash_player_18_plugin.msi"
"LastUsedSource"="n;1;C:\\Windows\\ccmcache\\2\\"
[HKEY_CLASSES_ROOT\Installer\Products\4769600BC08DBC8458D288DA63AE0B5A\SourceList\Media]
"DiskPrompt"="[1]"
"1"="DISK1;1"
[HKEY_CLASSES_ROOT\Installer\Products\4769600BC08DBC8458D288DA63AE0B5A\SourceList\Net]
"1"=hex(2):43,00,3a,00,5c,00,57,00,69,00,6e,00,64,00,6f,00,77,00,73,00,5c,00,\
  63,00,63,00,6d,00,63,00,61,00,63,00,68,00,65,00,5c,00,32,00,5c,00,00,00
i need a way to scan the reg for the old, or any flash product codes, NOT the msi GUID's to remove the keys..
Advocate ,
So are you saying that you need a way to remove anything with ' adobe flash ' in the following locations except for v18?:
IF so I would need a exported registry file from that location to use for testing, you can change the .reg to .txt and I can work with that.
I would also need to know if once found you want the entire key to be deleted? For example:
Last but not least can you work with an exe? As I would need to compile it.
I will make no promises, but i believe I can pull it off, it seems relatively simple if you want the entire key for that old product deleted.
I wrote something similar so I already have the foundation down and would require some tweaking.
yes, need the whole key removed...
according to the above post, the location for the keys is..
an exe would work, but a PS1, WMIC or bat file would be better..
the easiest way i can think of is search for this part of the key in those 3 locations
then have it remove the main key...
like this..
batch file - Search and Delete registry keys based on ProductName value - Stack Overflow
or if we had a list of all the product codes, that would work as well
Advocate ,
Well, I got something made that just does the HKEY_CLASSES_ROOT\Installer\Products\ currently, I do it basically by exporting that entire reg location and then read that file to memory then check line by line for ' adobe flash ' Once it finds it it checks to see if it is v18, if so, it keeps reading, if not it deletes the entire key, whatever that random number is. It is easier to do it that way then have it read from a list of hundreds of keys and compare them. I use AutoIT for my programming language, I find its easier to digest.
I can upload what i currently have which is only the first key , but should not take long to do the others as it is just copy/paste, make the necessary changes. its fairly fast as well when i strip the cpu throttling. You would need to PM me as i don't want to post a link up here. I don't have any keys other that 18 on my machines here.
Hopefully Maria can get the engineers to incorporate some additional cleaning into the uninstaller would be nice as well
Just let me know
p.s - the keys are the same across the board for all those locations, this will be gravy with 3 lines extra.
that should work, buy remember, i need to depoly this to run on remote pc's...
i was trying this.. but..
SET KEY=HKCU\Installer\Products
SET VALUE="Adobe Flash Player"
for /F "tokens=1,*" %%a in ('REG QUERY "%KEY%" ^| findstr /I /C:"%VALUE%"') do (echo REG DELETE "%KEY%" /v %%a)
but i get this output.. %%a was unexpected at this time.
Advocate ,
Give me a sec,
I am using HKEY_CLASSES_ROOT\Installer\Products\ to get the initial keys and then deleting them across the other two locations, so if there are other key that are in the other locations, and not in the reference location it will not pull them. I will have to add additional subroutines if you want me to check the other locations independently?
Do you want me to allow you to keep v18 stuff or remove it all?
remove all, i have seen some broke 18 installs as well..
Advocate ,
Check your mail please.
sha1:
1e3f7b6f0769d8c1ad1b3fae9281d1ca39e88d92
Advocate ,
after looking further looks like:
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Features
has them in there as well. I made the necessary adjustments and ran it on my machine. The adobe flash keys were successfully removed, nothing else. for all four registry location areas
I will send you a new link with a 3 at the end of file name
sha-1
E5E9DE7CE13056E5DA805BA9C560F90A8FD24FFB
Jul 16, 2015 Jul 16, 2015
found some more spots after logging a flash install
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\Features\
HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Installer\UpgradeCodes
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UpgradeCodes
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\
HKEY_USERS\S-1-5-21-2138466744-1268662106-1780572237-10545\Software\Macromedia\FlashPlayer
HKEY_LOCAL_MACHINE\SOFTWARE\Macromedia\FlashPlayerPluginReleaseType
Advocate ,
m_vargas
I am going to bring Maria into this as well, since I don't have any old versions on my machines, does the current uninstaller address these registry keys? Last time I tested the most current uninstaller it removed the keys; but that was the current version of FP
RussR123
You stated a few days ago that you were successful with a test machine for the script I provided; I guess some machines have addition reg entries that are preventing the install?
I can add the registry deletes in there, that will take a bit more time to modify the script esp for HKEY_USERS then and random SID under there, and remove anything adobe flash for those keys assuming I have them as well. I just need to know IF in your testing by removing those solves the problem?
yes, i have a few PC that flash is just "stuck" on... example..
this PC thinks it has 5 versions of NPAPI installed, and wont install the new .209
if i call the uninstaller, it says it uninstalls "ReturnValue = 0"
but if i re-call it again, it still see's all 5 still on there...
C:\Users\xx>psexec \\xx -s wmic product where "name like 'Adobe Flash Player%%NPAPI'" uninstall /nointeract
ive
PsExec v1.94 - Execute processes remotely
Copyright (C) 2001-2008 Mark Russinovich
Sysinternals - www.sysinternals.com
Executing (\\xx\ROOT\CIMV2:Win32_Product.IdentifyingNumber="{76CF5170-31B4-490F-89CE-5820EF416822}",Name="Adob
e Flash Player 18 NPAPI",Version="18.0.0.203")->Uninstall()
Method execution successful.
Out Parameters:
instance of __PARAMETERS
        ReturnValue = 0;
Executing (\\xx\ROOT\CIMV2:Win32_Product.IdentifyingNumber="{B0069674-D80C-48CB-852D-88AD36EAB0A5}",Name="Adob
e Flash Player 18 NPAPI",Version="18.0.0.194")->Uninstall()
Out Parameters:
        ReturnValue = 0;
Executing (\\xx\ROOT\CIMV2:Win32_Product.IdentifyingNumber="{2448A347-6E10-4FDE-AD25-74804743D184}",Name="Adob
e Flash Player 18 NPAPI",Version="18.0.0.160")->Uninstall()
Out Parameters:
        ReturnValue = 0;
Executing (\\xx\ROOT\CIMV2:Win32_Product.IdentifyingNumber="{44C61B0B-3700-4AA6-AC7C-EE8F0BA9A907}",Name="Adob
e Flash Player 17 NPAPI",Version="17.0.0.169")->Uninstall()
Out Parameters:
        ReturnValue = 0;
Executing (\\xx\ROOT\CIMV2:Win32_Product.IdentifyingNumber="{448D7DEC-36F1-4091-B419-C5487BDEB867}",Name="Adob
e Flash Player 18 NPAPI",Version="18.0.0.209")->Uninstall()
Out Parameters:
        ReturnValue = 0;
wmic exited on xx with error code 0.
Advocate ,
Can you try pushing the latest version of the Adobe flash uninstaller:
http://download.macromedia.com/get/flashplayer/current/support/uninstall_flash_player.exe
See if this resolves this maybe?
