OK, probably a simple question (and one that I can probably
figure out on my own, by testing it), but when selecting an image
file from an outside directory, does RH generate a copy of that
file in the working directory for the project? For example,
"image.jpg" currently resides in "C:\images", while my RH project
exists in "C:\RHProject"... When I select image.jpg from C:\images,
is a copy of it generated in C:\RHProject (and the image reference
for it set accordingly)?
I ask because, I currently have a "C:\images" directory,
where I've been saving all of my generated images and accessing
this directory from RH. I just today was cruising around the file
system, and I noticed some of the image files in the RH project
directory, as well... but not all of them. The thing is, my project
is huge, and I have hundreds of images. I don't specifically
remember which images are used and which are trash (i.e., whether
or not I re-worked or replaced some of them). Anyway, I really
don't want to have to perform a manual search between each
directory to verify... So, theoretically if all valid images are
copied to the RH working directory, I can just delete the images in
my "C:\images" folder.
Thanks for any feedback
- Chris
