quote:What PigBodine suggested...
Originally posted by: Peter Grainge
What other option do you have in mind?
quote:I'm not suggesting you should. Your solution seems to be viable and everything, it'll get the job done, but it's silly that a more intuitive and intelligent solution isn't already enabled by the application. It's not you that's frustrating, it's RH.
Originally posted by: Peter GraingeI cannot reprogram RH to fix the problem.
quote:What surprises me is that this isn't already available. Trying to select multiple folders was practically the first thing I did when I first touched RH7 and was quite dismayed over the fact that RH7 doesn't offer a seemingly very basic ability. After all, every other application or OS (that I can think of) that offers by-folder navigation or organization that I've run into also allows multiple selection of same. RH doesn't because...? (I ask rhetorically.)
Originally posted by: Peter GraingeIf applying tags to multiple folders at the same time is what you want, you'll need to let Adobe know that.
quote:Being able to select more than one folder at once? Seriously? That's incredible. Like I said, it was very nearly the first thing I did (well, tried). Weird!
In several years of supporting the forum, I've not seen anyone request this before.
I just had a similar issue where I only wanted to include a small subset of the files in one of my outputs. I managed to solve it using Peter's tip to put all the files I didn't want to include in a folder and then tag the folder. However, I think that an 'Include' expression would have made this much easier, as I believe it would have been in Dave's case too...
