About a month ago, I updated the SSL key for one of our
websites called webA. One of our other websites, webB, on the same
server is making a CFHTTP call to webA using SSL. This has worked
fine for the past 2-3 years. It seems that after I renewed and
installed the SSL key for webA, webB gets the following error when
using CFHTTP:
Connection Failure: Status code unavailable <br>The
error occurred on line 1.
I was reading this article that says CF doesn't support newer
SSL keys using SSL v3.
http://www.talkingtree.com/blog/index.cfm/2006/11/14/ColdFusion-Protocol-Tags-CFHTTP-CFINVOKE-CFLDAP...
So, I tried using another JAVA library to simulate CFHTTP,
but ran into the same problem
http://www.innovation.ch/java/HTTPClient/
So I started searching the SUN website and got a hint that
perhaps the JVM was the problem. So I upgraded my JVM from
j2sdk1.4.2_11 to j2sdk1.4.2_15
I tried again and my CFHTTP tag was working again and so was
the java HTTPClient library I tried.
Has anyone else had this problem?
Has anyone tried and had any problems with using CF with
j2sdk1.4.2_15 ? I don't think CF officially supports it.
I've only done this on our development server and need to
perform more testing with this new JVM before putting into
production.
Thank you for any feedback.,
Carlos Vazquez
Senior Web Developer / MySQL DBA
