I am trying to use RH11 to convert a bunch of .dita files to .html, but so far have had no success. I have DitaOT installed in my program folders.
I've been opening robohelp, selecting new project -> import -> ditamap file. select the ditamap to use, create a new folder for the project, hit next.
In the replace default XSLT file for conversion field, I put in the dita2html-base.xsl file.
In the DITA Open Toolkit home directory field, I navigate to the location of the DitaOT root folder, select it, and click finish.
When I click, finish, robohelp almost immediately gives me an error message saying "No error occurred", leading me to believe that I filled out all of the required fields correctly, but when I check the output folder I created, it is empty.
Any tips on things to try/ what I should change would be very appreciated (or if i'm trying to force RH to do something that it isn't normally able to do, that would be appreciated as well).
Let us know if this info works for you.
Amit
