Hello All
I have a problem.
The computers behind the firewall.
I disable updates from the Flash Player Settings Manager in Control Panel.
Problem:
I open IE to connect intranet web, Homepage has flash, status is fine.
when change to second page, it is lag.
because flash try to connect to internet but the computers can't connect to internet.
TTT Analysis Information:
0:024> kcnL
00 mswsock!MSAFD_ConnectEx(unsigned int s = 0xb9c, struct sockaddr * name = 0x093a0be4,
01 wininet!CWxSocket::ConnectRequest
02 wininet!CWxSocket::Connect
03 wininet!ICSocket::Connect_Start
04 wininet!CFsm_SocketConnect::RunSM
05 wininet!CFsm::Run
16 wininet!CFsm_HttpSendRequest::RunSM
17 wininet!CFsm::Run
18 wininet!DoFsm
19 wininet!HttpWrapSendRequest
1a wininet!HttpSendRequestW
1b flash11c!DllUnregisterServer
1c ntdll!RtlpLowFragHeapAllocFromContext
1d iertutil!DSA_InsertItem
1e iertutil!_AddGITCookie
0:024> !addr 0x093a0be4
SOCKADDR @ 093a0be4
sin_family = 2 (IP)
sin_port = 80
sin_addr = 210.61.248.49
0:024> .frame 16
16 22d6f6fc 76c1d241 wininet!CFsm_HttpSendRequest::RunSM+0x34
0:024> dv
Fsm = 0x0448aea0
error = 0
pRequest = 0x1691f690
0:024> dt pRequest 0x1691f690 _CacheUrlName
Local var @ edi Type HTTP_REQUEST_HANDLE_OBJECT*
+0x1a4 _CacheUrlName : 0x04509648 "http://fpdownload2.macromedia.com/get/flashplayer/update/current/install/version.xml10.0.45.2&lang=z..."
Hi hotingy14973707,
Based on the output you provided, Flash Player is not attempting to update, or check for an update. After Flash Player is installed, the first time Flash content is viewed Flash sends a ping back to adobe servers with some metadata (e.g. OS version, player type, OS language) used for metrics data only. Unfortunately, there is no way to disable this in Flash Player.
Maria
