In older versions of robohelp you could replace an image without losing the hotspots, how do you do that in robohelp 11
Are the images added by reference? If so, you should be able to swap out a new image for the old as long as the file path & name stay the same.
Hi there
The simplest way is to just save the image to the same location using the same file name. Do this outside of RoboHelp. RoboHelp won't know any difference.The only issue you are likely to encounter is if the new image is a different size than the one you are replacing. If so, you will likely have to tweak the hotspots in RoboHelp.
Cheers... Rick
Thank you very much! That was easy.
Diane S. Medeiros
Director of QA & Technical Support
ProfitKey International, LLC
