Next time you generate, you will see in the wizard the build
expression you created. It is in a dropdown. Select None instead of
that expression.
Yes it is a problem with your other project but if you don't
want to take your car to the garage, you can't expect them to
diagnose the fault.
I've lost count of the number of projects sent to me. Nobody
has had cause to complain and as Adobe would strip my Adobe
Community Expert status, I'm hardly going to risk that. Your call.
My project works fine! Seriously, the option to put to your
management is they accept this free offer or pay to get a consulant
in.
There are some other things you can try first. I think I have
pointed you before to my Opening Project page. Try that. If not, in
a test project, create build tags exactly the same as your problem
project. Then copy the rhbuildtag.apj file to your problem project.
Do work on backups while you do all this.
