I copied htmls down from the published website. then I
created a new project and carefully built the TOC by importing
htmls. I must have deleted the first topic instead of cutting and
pasting.
When I compile, I get no error messages. But View webhelp
does not work. When I go to the webhelp directory and select what I
think should be my first page, it displays as a simple html (NO
TOC, no navigation).
I peeked at the xml file with notepad and it says:
<?xml version="1.0"?>
<!DOCTYPE SYSTEM "ehelpopt.dtd">
<FILE-OPTIONS FILE-VERSION="2"
FILE-KEY="ff94dc00_f498_492c_9c9d_f8897903aff0">
</FILE-OPTIONS>
<EHELP-OPTIONS FORMAT-VERSION="1.0">
<OPTIONS ENABLED="NO" EMBEDDED="YES"
MAIN-WINDOW-ONLY="NO" COMMUNITY-NOTIFY="NO"
FIRST-PAGE="NOT-SET">
</OPTIONS>
<BUTTON-LABEL>WebSearch
</BUTTON-LABEL>
</EHELP-OPTIONS>
Text
You can see the first page= "not-set"
Is that my problem? If so can it be fixed without starting
over?
