Hi !
Can you show me how to make a circle ( with divided by 8 lines ) , There are 4 letters A B CD on that circle line, and they turn around then around. When a letter turn to the position 90*, it becomes bigger, when it pass away from that, it backs to the previous mode.
Thanks so much
Can you give us more infos plz ?
Like if you wanna have it only as an animation, or may it be interactive ?
Because you can make it on the easiest way with pre-generated animation's movieclip, or full dynamically generated with code.
Thanks for reply
It can be interactive.
when a letter turn to the 90* position, it wll stop 2-3 second, and become bigger. When it stop, you can click on it. The other letters are similar to that.
Ok thanks for this explanation.
So basically, I see it on 2 possibles ways :
- animation-side : you could create the movieclip with the full animation for a full loop. All the letters will be tweening through a motion guide, by this, they won't rotate on themselves. But you need some interactivity, so you will need to add some code in the letter movieclip (the basic MouseEvent.CLICK dispatcher, and add the listener fonction of course).
- as3-side : more tricky, but most powerfull the one. You'll have to handle it with angles calculations, then easily do a pause every 20° as instance, and activate the interactivity on the letter concerned.
By the way, what are your AS3 programming skills ?
Thanks your help.
abc-final-final.swf - Google Drive
