We recently updated java. Uncertain if this is possibler cause or coincidence. cf8 server. Other development servers without update cffeed working per usual.
Error:
Unable to parse the feed: Either source specified is invalid or feed is malformed.
Error: Invalid XML
What was the version before the upgrade, and what is the version after upgrade?
I know (from experience) that CF8 has a serious issue with Java 7 u25 and later. Apparently, the geniuses at Oracle closed some default network permissions and it's a huge PITA to clear.
V/r,
^_^
Java before and after upgrades.
Java 1.6.0_16 to 1.8.0_31
Appreciate any help.
On Tue, Jul 28, 2015 at 12:49 PM, WolfShade <forums_noreply@adobe.com>
CF8 will not support Java 8.
It will only support up to Java 6, which means the issues you are getting is probably due to compatibility with the JRE.
I think 1.6.0_24 is the highest support version for CF 8
