In RoboHelp for word you could auto generate map IDs. I have found how to do it in RoboHelp 11 but it states the following in the help "By default, the application assigns the topic title or filename as the topic ID and assigns map number" It used the topic title and I need it to use the file name. Is there a setting where I can specify to use the file name?
If I understand you correctly, you want to use the topic filename for the topic ID? You can manually specify a topic ID so that would be a good workaround. You can also script this behaviour to have an automatic mapping.
