Reading CMYK jpeg images
Jul 30, 2015 Jul 30, 2015
I am unable to read CMYK jpeg images from coldfusion 10. Below are my server configuration.
Coldfusion 10 (update 14),32 bit and windows 2008 r2 64 bit,jre(1.6)
i found below code in java and implemented in coldfusion,but the code is working fine in coldfusion 10 64 bit,but not coldfusion 32 bit.
Shall i get any help on this?
public class CMYKTiffToJpegConvertor {
  public CMYKTiffToJpegConvertor() {
  // TODO Auto-generated constructor stub
  public static void main(String[] args) throws IOException, Exception
  new CMYKTiffToJpegConvertor().processConvertionImage(ImageConstants.FILE_PATH,ImageConstants.INPUT_FILE_NAME);
  System.out.println("Successfully Completed the conversion!!");
  * @Param filePath
  * @Param fileName
  * @throws IOException
  * @throws Exception
  public void processConvertionImage(String filePath,String fileName) throws IOException, Exception{
  fileName = filePath+fileName;
  BufferedImage img =  readImage(fileName);
  String milliSec = new String(""+new Date().getTime()+"_");
  String path = filePath+milliSec+ImageConstants.OUTPUT_FILE_NAME;
    ImageIO.write(img,"jpg", new File(path));
  public static final int COLOR_TYPE_RGB = 1;
    public static final int COLOR_TYPE_CMYK = 2;
    public static final int COLOR_TYPE_YCCK = 3;
    private int colorType = COLOR_TYPE_RGB;
    private boolean hasAdobeMarker = false;
     * @Param filename
     * @Return
     * @throws ImageReadException
    public BufferedImage readImage(String filename) throws IOException, ImageReadException {
        File imgfile = new File(filename);
        ImageInputStream stream = ImageIO.createImageInputStream(imgfile);
        Iterator<ImageReader> iter = ImageIO.getImageReaders(stream);
        while (iter.hasNext()) {
            ImageReader reader = iter.next();
            reader.setInput(stream);
            BufferedImage image;
            ICC_Profile profile = null;
            try {
                image = reader.read(0);
            } catch (IIOException e) {
                colorType = COLOR_TYPE_CMYK;
                checkAdobeMarker(imgfile);
                profile = Sanselan.getICCProfile(imgfile);
                WritableRaster raster = (WritableRaster) reader.readRaster(0, null);
                if (colorType == COLOR_TYPE_YCCK)
                    convertYcckToCmyk(raster);
                if (hasAdobeMarker)
                    convertInvertedColors(raster);
                image = convertCmykToRgb(raster, profile);
            return image;
        return null;
     * @Param file
    public void checkAdobeMarker(File file) throws IOException, ImageReadException {
        JpegImageParser parser = new JpegImageParser();
        ByteSource byteSource = new ByteSourceFile(file);
        @SuppressWarnings("rawtypes")
        ArrayList segments = parser.readSegments(byteSource, new int[] { 0xffee }, true);
        if (segments != null && segments.size() >= 1) {
            UnknownSegment app14Segment = (UnknownSegment) segments.get(0);
            byte[] data = app14Segment.bytes;
            if (data.length >= 12 && data[0] == 'A' && data[1] == 'd' && data[2] == 'o' && data[3] == 'b' && data[4] == 'e')
                hasAdobeMarker = true;
                int transform = app14Segment.bytes[11] & 0xff;
                if (transform == 2)
                    colorType = COLOR_TYPE_YCCK;
     * @Param raster
    public static void convertYcckToCmyk(WritableRaster raster) {
        int height = raster.getHeight();
        int width = raster.getWidth();
        int stride = width * 4;
        int[] pixelRow = new int[stride];
        for (int h = 0; h < height; h++) {
            raster.getPixels(0, h, width, 1, pixelRow);
            for (int x = 0; x < stride; x += 4) {
                int y = pixelRow;
                int cb = pixelRow[x + 1];
                int cr = pixelRow[x + 2];
                int c = (int) (y + 1.402 * cr - 178.956);
                int m = (int) (y - 0.34414 * cb - 0.71414 * cr + 135.95984);
                y = (int) (y + 1.772 * cb - 226.316);
                if (c < 0) c = 0; else if (c > 255) c = 255;
                if (m < 0) m = 0; else if (m > 255) m = 255;
                if (y < 0) y = 0; else if (y > 255) y = 255;
                pixelRow = 255 - c;
                pixelRow[x + 1] = 255 - m;
                pixelRow[x + 2] = 255 - y;
            raster.setPixels(0, h, width, 1, pixelRow);
     * @Param raster
    public static void convertInvertedColors(WritableRaster raster) {
            for (int x = 0; x < stride; x++)
                pixelRow = 255 - pixelRow;
     * @Param cmykRaster
     * @Param cmykProfile
     * @Return
    public static BufferedImage convertCmykToRgb(Raster cmykRaster, ICC_Profile cmykProfile) throws IOException {
        if (cmykProfile == null)
            cmykProfile = ICC_Profile.getInstance(CMYKTiffToJpegConvertor.class.getResourceAsStream("/ISOcoated_v2_300_eci.icc"));
        if (cmykProfile.getProfileClass() != ICC_Profile.CLASS_DISPLAY) {
            byte[] profileData = cmykProfile.getData();
            if (profileData[ICC_Profile.icHdrRenderingIntent] == ICC_Profile.icPerceptual) {
                intToBigEndian(ICC_Profile.icSigDisplayClass, profileData, ICC_Profile.icHdrDeviceClass); // Header is first
                cmykProfile = ICC_Profile.getInstance(profileData);
        ICC_ColorSpace cmykCS = new ICC_ColorSpace(cmykProfile);
        BufferedImage rgbImage = new BufferedImage(cmykRaster.getWidth(), cmykRaster.getHeight(), BufferedImage.TYPE_INT_RGB);
        WritableRaster rgbRaster = rgbImage.getRaster();
        ColorSpace rgbCS = rgbImage.getColorModel().getColorSpace();
        ColorConvertOp cmykToRgb = new ColorConvertOp(cmykCS, rgbCS, null);
        cmykToRgb.filter(cmykRaster, rgbRaster);
        return rgbImage;
* @Param value
* @Param array
* @Param index
    public static void intToBigEndian(int value, byte[] array, int index) {
  array[index] = (byte) (value >> 24);
  array[index + 1] = (byte) (value >> 16);
  array[index + 2] = (byte) (value >> 8);
  array[index + 3] = (byte) (value);
918
Enthusiast ,
Aug 03, 2015 Aug 03, 2015
I gave up using ColdFusion-related image functions. I've still identified CMYK images that can't consistently be read by ColdFusion 10.  I also still have some apps running on ColdFusion 9 and needed a solution that was backwards compatible.
I started using CFX_OpenImage, but it hasn't been updated in a while.  I recently wrote a ColdFusion Custom Tag to access GraphicsMagick.  It can be installed on pretty much any 32-bit or 64-bit operating system.  It supports 88 major formats including important formats like DPX, GIF, JPEG, JPEG-2000, PNG, PDF, PNM, and TIFF.  This method is faster than CFImage and often generates much smaller files.
Here's the link to the custom tag if you are interested.:
http://gamesover2600.tumblr.com/post/125766251344/graphicsmagick-coldfusion-custom-tag
Converting any JPG to a non-CMYK JPG can be done by:
<CF_GraphicsMagick action="Optimize" Infile="#ImageIn#">
Documentation
