Okay, so I use the browser Opera and the Flash Player for that one is PAPI, and when I play TO the graphics are bad with mip-mapping on. I use NPAPI for that reason and it worked pretty fine, but now I can't find any. Pls help me D:
In short, I want to download the NPAPI version In Opera --- please help ASAP
Hi ffsas38745037,
Older versions of Opera use the same NPAPI plugin as Firefox. Therefore, you can download the NPAPI plugin for Firefox and use that with the older version of Opera. You don't specify if you're using OS X or Windows. For Windows download it from Installation problems | Flash Player | Windows. For Mac, download it from Installation problems | Flash Player | Mac
You can also try to disable the PPAPI and use the NPAPI plugin by doing the following:
please Moderators post a reply and heelp me
Patients is a virtue, posting 30 minutes after the original post is not going to escalate the matter son, or you could have searched the forums
My suggestion is to download the offline installer at the bottom of the page here: Installation problems | Flash Player | Windows
Regards
I want the link of NPAPI in the Opera browser Please. tell me
I provided the answer, please read the post and link documentation thoroughly.
Have a Great Day and Good Luck!
aree you noob??
i dont want PPAPI i want a NPAPI version plzz,, if you dont know please dont reply -.-
Hi ffsas38745037,
NPAPI for flashplayer is no more supported in the latest versions of Opera (After 25.0). So you either have to go with PPAPI or, an older version of Opera.
Deepankar
can you please tell me how to download it in an older version of Opera ???
i neeeeed it in anything i just need it for anything
Hi ffsas38745037
Download Opera version which is less than 25v .
http://www.opera.com/download//?os=windows&list=all
Sreeharsha
with NPAPI???
Hi ffsas38745037,
Note: I have the latest version of Opera on OS X 10.10.3 (Opera 30.0.1835.125) and on Windows 7 SP1 64-bit (Opera 30.0.1835.157) and this did not work for me on either OS. It may, or may not, work for you.
Also, I'm not sure if the mip mapping behaviour you are observing when using PPAPI with Opera is a known issue or not, as such, it'd be great if you could file a bug at https://bugbase.adobe.com/. Please provide all required information and an URL or sample code that you are observing this on.
Maria
thankk you very much^
