In my view you may convert each RTF file to PDF in memory and next next merge PDF documents into single PDF:
1. Convert each RTF to PDF in memory
SautinSoft.PdfMetamorphosis p = new SautinSoft.PdfMetamorphosis();
ArrayList pdfs = new ArrayList();
//1st RTF to PDF
byte[] pdf = p.RtfToPdfConvertByte(rtfString1);
pdfs.Add(pdf);
//2nd RTF to PDF
pdf = p.RtfToPdfConvertByte(rtfString2);
//etc, or you may use loop
pdfs.Add(pdf);
2. Merge several PDF to single PDF on fly
//merge to single PDF
byte[] singlePDF = p.MergePDF(pdfs);
//show PDF
if (singlePDF != null)
Response.Buffer = true;
Response.Clear();
Response.ContentType = "application/PDF";
Response.AppendHeader("content-disposition", "attachment; filename=single.pdf");
Response.BinaryWrite(singlePDF);
Response.Flush();
Response.End();
This code uses the .Net component 'PDF Metamorphosis .Net', so it will also work in CF8.
Best wishes,
Max
