Hi Krishna
Sorry to err on the side of being overly cautious. I deal
with other forums where there are individuals that have egos the
size of the B-15A iceberg, and feel any other viewpoint or
suggestion offered is entirely detrimental to the thread. Instead
of viewing the information for what it is, an attempt to try and be
helpful, they view it as unwanted intrusion and a threat to their
very survival. (Please note that I'm not saying Colum fits that
description, just that I've seen it with great regularity in other
forums I visit)
Hmmm, I may have found an easy way to accomplish this. Locate
a file in your project folder that is named whtopic.js. Open this
file in Windows Notepad. Tap the F3 key and search for the phrase
sType=="show".
You should see something similar to this:
else if(sType=="show")
if(isTopicOnly()&&(!gbOpera6||gbOpera7))
var sTitle="Show Navigation Component";
Add a line to the code just above where you see var sTitle=
so the line now looks like this:
setTimeout('show()',1);
Close and save the file and test. There should be no need to
re-generate. You should also make a backup copy of your file so you
can easily replace it when you generate.
Hopefully this helps... Rick
