quote:Yes and I don't know. 🙂 When it crashes it always occurs when I'm moving one folder into or out of another. If figured that re-organizing things was at the limit of RH's abilities and sometimes it broke as a result. Since I don't have to move that many more folders yet in the project I just let the whole issue go, believing that since I won't be doing the thing RH doesn't like any more (to speak of) the problem wouldn't be encountered again.
Originally posted by: Peter GraingeYou don't give us anything to go on. Is your project local? Does this happen with the sample projects?
quote:No, I haven't, I just assumed it was normal for the app.
Originally posted by: Peter GraingeHave you tried any of the methods suggested for troublesome projects? See Opening Projects on my site for a start.
quote:That could very well be. This is a project with tons and tons of topics and (non-multi-selectable) folders (still bitter about that) that were created in an unknown-to-me version of RH. The chances of it not being set up correctly or of a corrupt file somewhere are probably high for all I know. The topic on your site offers much in the way of good advice as to what to do. (Though, as a quick aside, it references Access a few times I noticed during my brief skim, I assume I don't need access to Access to carry out the fixes, correct?)
Originally posted by: Peter GraingeI found all sorts of things wrong and once they were fixed, it worked fine here.
quote:Hee! I would post a snark about Windows apps in general but that's not the topic of the forum... ;)
Originally posted by: Peter GraingeIf the problem was common and was RH, nobody could work with it.
quote:
Originally posted by: HKabaker
I leave RH 7 running all day long, sometimes with a project open while I'm busy elsewhere. I work on the project for awhile, move to a different task for a few minutes or hours, and come back to RH. It's always waiting for me where I left off.
MeWrite, you should review all the options selected for when and how the machine behaves on battery -- time limits for screen dim, screen sleep, disk sleep, anything else.
Harvey
