Hi kt
The attached code should be copied and pasted into an
instance of Notepad. After you do this, change your .CHM file name
and save the file as autorun.inf. Then make sure you include the
autorun.inf file on the CD.
Note: Make sure your .CHM filename is only 8 characters long.
For example, don't use My Wonderful CHM.CHM. Instead, use something
like WondrCHM.CHM. (Longer filenames often prevent autorun from
working correctly)
Hope this helps a tad... Rick
