Purchased LR6 DVD from Adorama but the installer won't connect to the internet so I can register. Internet is working fine. I have Adobe account.
I switched from Safari to Chrome and downloaded the trial version hoping to get around the DVD version but I can't get the program to start. I get the same message that I should connect to the internet and sign in. It seems undoable after 3 hours. Spent an hour chatting with support in India.
Also delete Lightroom cookie and reg file and then enter serial number and check.
Windows :
Press Windows button (located between Ctrl and Alt buttons) along with R button together at a time , you will get a run command window.
Type in below command and hit 'Enter' key.
%programdata%
It will open ProgramData folder. inside locate Adobe folder.
Navigate to Adobe > Lightroom.
Open Lightroom and delelete all files inside ,
Then launch LR 6 and enter serial number,
Mac :
1) Right click on Finder icon and se
...Copy link to clipboard
Hi Lee,
Please refer to the link: Creative Cloud activation and sign-in troubleshooting
Sheena
I have not purchased anything called a Creative Cloud. I don't know what it is. I want my copy of Lightroom 6 to switch from Trial to regular. It is counting down each day.
Hi Lee,
This link might help: Re: lightroom is in trial mode, but I have purchased a subscription.
Please try the solution mentioned.
Sheena
I followed your instructions;
I'm not sure why a Lightroom 6 program downloaded from the DVD would not be the program that I paid for. I have done nothing to suggest an interest in CC.
I'm not sure why erasing Lightroom 6 and replacing it with Lightroom 5.7.1 is a desirable outcome. Why can't I have what I paid for?
I erased 6 and downloaded 5. When I put in my serial number I got a red X with no explanation. What have I accomplished?
Lee I suppose there is some issue coming up with the activation for LR6.
Please Contact Customer Care where the agent can remote into the machine and fix the issue for you.
It was activated before I erased it. It was activated as a trial version. I suppose, before I call customer care I should reload Lightroom 6 from the DVD.
Sure.
Windows :
%programdata%
Mac :
1) Right click on Finder icon and select "Go-To Folder" option.
2) You will get a text box, type-in below command and then hit 'Return' key.( " Do not miss ~ symbol " )
~/library
It will open User Library folder.
3)Then navigate to Application Support>Adobe>Lightroom.
That seemed to work. Thanks a lot. I figured that something had to be trashed. I had Lightroom 6 for a day. Now I have a 24 day countdown for something called Lightroom Mobile which I never asked for and don't care about. The remaining question is, once this 'mobile' countdown ends, will I still have Lightroom 6 on my Macbook Pro?
Thanks again.
It will not affect Lightroom 6 on your MacBook Pro .
You are welcome .
At any point , if you face any kinda issue , feel free to post
Let me know whether you had checked with below steps :
1) Unchecking Proxies .
2) Trashing Opm.db file ?
3) Checked Hosts file .
4) Removed and reinstalled Adobe Application manager ?
