sorry, can't help you with that, really, as i have never used
or even
heard of the PDSeditor... i understand it is some sort of
rich
text/HTML/WYSIWYG editor replacement for textareas, but i
have not used
it. i prefer tinyMCE, and a long time ago i used to use
SOeditor, and
now will probably switch over to FCKeditor since CF8 has it
built-in...
but... if your ADD PROJECT page (or other pages) works fine
with this
PDSeditor and saves the text you enter in the textarea into
the db, then
it should work on the edit project page, too...
the function you posted, though, seems to just return the
text you type
into this PDSeditor to the textarea... this js is called on
form
submit... there must be another js function (or maybe even a
whole js
library) that loads and initiates the PDSeditor instance(s)
on the
page... if you can't see anything like that in your edit page
(either
in-line js or included as external file) then maybe that is
why it is
not working... look in the source of a page where the
PDSeditor does
work to see how it is included/initialised and add same code
to the edit
page if it is missing there.
strange, though, that you only have NAME attribute and no ID
attribute
for the textarea - most js works with ID attribute to select
an element
in the DOM as it is a lot easier than using NAME attrib....
maybe you
are missing a required ID attrib of the textarea and that's
why the
PDSeditor does not load as it does not see the element to
take over?
as a last resort, i would try just removing that
style='display:none'
from your textarea to see if it matters at all or not...
on another issue, looking at the code for your SELECT form
element (the
CATEGORY drop-down select), it looks like on the EDIT PROJECT
page it
will display ONLY ONE category - the one that has been
previously
selected for the project. what if i want to change the
project category?
maybe you should populate the SELECT with all categories, but
pre-select
the one that is currently associated with the project.
also, in your projMan query you do not need the AND
c.CategoryID =
p.CategoryID in the WHERE clause - you already have that
constraint in
the INNER JOIN...
hth
Azadi Saryev
Sabai-dee.com
http://www.sabai-dee.com
