Current project: Web Help currently in RoboHelp for Word 10 with a lot of conditional text, many see alsos and related items, and multiple single-source layouts. Upgrading to RH 11 and will use Responsive HTML layout
I thought it might be best to first convert the RH for Word 10 project into a RH HTML 10 project, then upgrade it to 11. Since I haven't found anyone who has actually done the conversion, I thought I'd check here to see what y'all have experienced.
Take a look at Item 8 at Snippets (Rh for Word). It covers your scenario albeit based on an older version. I hope it helps.
Come back to the forum with any issues you encounter. Whatever you do, create a backup first so that you can roll back or try again with a clean source. I always prefer to zip backups as you can then extract as many copies as you may need. Also it stops you accidentally opening the wrong copy of your project.
Thanks, Peter. Luckily, I have not problems so far with the styles.
However, Conditional Build Tags and Single Source Layouts that were in my Word (hpj) project do not appear in the HTML (xpj) project after I convert it. Any tips for this issue?
And the TOC links are breaking. Each link looks like it is referencing a chm file. (This project has never been a chm file)
Try recreating one of the tags and then look at its properties. Does it show the tag as being used in the topics?
Not sure about the layouts. You may just have to recreate them.
Also not understanding why or even how the links can point to a chm. Would recreating it be a massive task?
Just an update for anyone else who might have these issues.
When I recreated the tags and looked at their properties, the topics were listed. However, at some point the connection between the topics and tags were lost, so I need to reapply them. Not a small task, but I can't find a workaround.
Layouts
Yes, I will have to recreate them. Luckily, this project only has 2, not 20 like some other projects.
TOC Links
I deleted the original conversion and re-opened the project. In the import/conversion process, I selected Retain for the external links. Then I opened the .hhc file in Notepad ++ and updated all the TOC links from there. Much quicker and easier than using the RoboHelp UI.
Usually when the tags don't appear and you recreate them in the way I suggested, the link is restored. The tag went missing but not the code in the topics, hence when the tag was recreated it knew which topics were associated. Are you saying that even after recreating the tags, if you go to Topic Properties there is no reference to the tag and that no shading appears?
