TOC topics don't stay in view
Jan 17, 2008 Jan 17, 2008
When I select a topic from the table of contents, instead of it
remaining in the pane, it slides down and the top book is at the topic
of the pane. I have to scroll down to find the topic, which is still
highlighted.
Has anyone got a fix for this? I've never encounted this
before. The topic should appear in the pane so I can go to the next
topic. Thanks!
1.0K
Enthusiast ,
Jan 22, 2008 Jan 22, 2008
Kate,
Which version of RH are you using?
There's a patch for RH 6, posted a while back, and I think it's fixed in RH 7.
Harvey
The customer requires RH6. I'll search for the patch. Thanks!!
I looked on Adobe RH patches and didn't find any for RH6. Does anyone know where to find this patch? Thanks!
Enthusiast ,
Peter Grainge's Snippet # 49 might do it for you.
http://www.grainge.org/pages/snippets/snippets.htm
This patch prevents that final scroll to the top after highlighting the current topic.
Harvey.
Enthusiast ,
If you have RH 7, I think you can safely substitute the new version of whthost.js from the output directory for the file of the same name in the RH 6 output directory. The code is identical except for lines 272, 426, 727, 728, and 730 all of which pertain to the vertical scroll.,
Lines 1031 and 1032 fix a problem in the horizontal display when the TOC lines are longer than the TOC pane is wide.
You can take this file from any output directory, because it is the same for all WebHelp outputs.
(As always, test on a backup copy of your output to be sure this won't break something else in the TOC display.)
Harvey
I used the snippit. It works in IE. Problem is... I think we have some Firefox users. I don't have RH7. I'll see if I can find it. Does that fix work in Firefox and IE?
dup
Plus, the snippit suggestion has to be reimplemented each time the help is generated. If I find the RH7 file, is it a perminent fix through any number of WebHelp generations? Thanks!
dup
Enthusiast ,
Jan 23, 2008 Jan 23, 2008
Kate,
Unless you upgrade to RH 7, each time you generate WebHelp you have to replace or patch whthost.js.
Far as I know, Firefox and Netscape work the same as IE on this issue.
I get no commission for this, but I suggest upgrading to RH 7. Why does the client require RH 6? Was it before RH 7 was released?
Harvey
Worth pointing out to the customer the RH6 to RH7 upgrade is only $80?
Jan 24, 2008 Jan 24, 2008
Thanks. I will point out the upgrade. They looked at RH7 when it first came out and were scared off by the inital bugs. Is it pretty stable?
There are some issues listed on my site. I am using it daily though for production and wouldn't step back to RH6. Does that help?
Enthusiast ,
Kate,
IMHO, RH 6 was a life-support measure for Adobe to get something they could label Adobe RH into the market before we all jumped ship. It did make some improvements over X5.
X7 is a leap forward, fixing a lot of old stuff, introducing a new (better) interface and adding enhancements that make my life a lot better.
If "they" start talking about RH 7 "bugs" beyond Peter's notes, please post here on those issues.
Harvey
RoboHelp Documentation
Download Adobe RoboHelp
